06-27-2017, 16:13 | #1 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,163 | XTC 2 PowerAdapter - How to use (manual) For complete XTC 2 Power Adapter please visit this thread: http://forum.gsmhosting.com/vbb/f961...017-a-2233953/ Here is a short manual on how to use the new PowerAdapter, and in the meantime we will prepare videos and photos for this guide. What do we need? * XTC 2 Tool version 1.31 and higher from here: http://forum.gsmhosting.com/vbb/f961...pport-2238267/ * Drivers for PowerAdapter from here: http://xtc2.net/downloads/driver_poweradapter.zip How to use: 1. Connect XTC 2 PowerAdapter to PC using microUSB cable and install drivers, if not yet installed. 2. Remove smartcard from XTC 2 Clip and insert PowerAdapter instead. Shoul you feel that connection is not tight enough, you may use included stickers to secure the connection. 3. Run XTC 2 Tool and open "PowerAdapter" tab. 4. Connect phone in download mode to PC, and connect XTC 2 Clip to phone's SD slot as for normal S-OFF operation. 5. Process with desired command. Quote:
The Following 16 Users Say Thank You to xtc2clip For This Useful Post: |
06-27-2017, 16:53 | #4 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: Poland
Member: 2085623 Status: Offline Thanks Meter: 221 | What you select from log I see that you do S-ON procedure not S-OFF or maybe software got bad parametr under button. Quote:
06-27-2017, 17:20 | #6 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2589530 Status: Offline Thanks Meter: 2 | write security s-off 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 Building connection Initiating communication Building connection Data exchange sequence. Requesting information from server Requested sent, waiting 3 seconds for reply... Processing... Data exchange completed Data exchange sequence..... (bootloader) Write security level S-ON OKAY Execution time is 9(s) Operation completed! Releasing adapter. Request completed write security s-on 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 3 ... (bootloader) HTC KEY CARD VERSION: 7 (bootloader) VERIFY_PASS (0) (bootloader) Partition verify pass Building connection Initiating communication Building connection Data exchange sequence. Requesting information from server Requested sent, waiting 3 seconds for reply... Waiting 3 seconds more... Processing... Data exchange completed Data exchange sequence..... (bootloader) Write security level S-ON OKAY Execution time is 14(s) Operation completed! Releasing adapter. Request completed |
06-27-2017, 17:44 | #7 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,163 | Hello, As we wrote before, there is a stock of phones that does not support permanent S-OFF, you can repair IMEI, change CID, reflash phone, etc, or/and unlock bootloader - unlocked bootloader gives almost same option as S-OFF. There is currently no known option to perform permanent S-OFF, as HTC did not implement this feature. |
06-27-2017, 17:54 | #8 (permalink) | |
Freak Poster Join Date: Nov 2015 Location: Taipei, Taiwan
Member: 2487890 Status: Offline Thanks Meter: 72 | Quote:
我從使用 Tapatalk 的 HTC_M9u 發送 | |
06-27-2017, 18:00 | #10 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,163 | Quote:
P.S. Are there any locked U Ultra/Play and U11? Please let me know if you have one. P.P.S. As I already said before, support area will be updated shortly after the official launch of PowerAdapter, which happened today | |
06-27-2017, 18:00 | #11 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1247453 Status: Offline Thanks Meter: 13 | So what do you want permanent s-off?. While s-off do, your downgrade, sim unlock, etc. Then there is no need to worry, the downgrade or sim unlock will already be done. Enviado desde mi HTC One_M8 mediante Tapatalk |
06-27-2017, 18:14 | #13 (permalink) | |
Maybe japanese model of U11 have simlock, not sure about that. 我從使用 Tapatalk 的 HTC_M9u 發送 | |
06-27-2017, 18:18 | #14 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,163 | The phone does the security checks not only whenever the whatever command is issued, but on reboot also, so once rebooted with Trusted Reboot option, phone should allow downgrade, and factory reset from menu, which is hidden when the phone is S-ON and clip is not connected. |
06-27-2017, 18:36 | #15 (permalink) | |
1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem readimei ... (bootloader) imei: 355167080362310 OKAY Execution time is 6(ms) Operation completed! Releasing adapter. Request completed | |
