Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 08-29-2017, 16:06   #61 (permalink)
Member: 2416253
Thanks Meter: 3,757
Originally Posted by ismath0094 View Post
i successfully s-off htc 530 with power adapter. its working. please help me to s-off using power adapter for htc desire 10 pro and htc m10
thank
Hi!
I can only suggest to check how you connect the flex to the phone, and that the flex isn't damaged. According to your logs it's a connection problem between the phone and the clip.
Old 08-30-2017, 03:16   #62 (permalink)
Member: 2592998
Thanks Meter: 6
Originally Posted by Zanziman View Post
I was able to unlock my Sprint U11 SIMLOCK using the method posted in the thread I linked above. I did not have whatever DM errors you encountered.
For the record: All U11s are NOT the same. The Sprint model is different than the Unlocked model.
Same thing was true with the HTC 10. Both the Verizon and Unlocked model have the same MID. However, the MID of the Sprint model is different than those as well.
Apparently the U11's must be pretty much the same, as I myself and others have converted our sprint U11'S over to the unlocked version by means of root ninja s-off via the sunshine app then change the cid to the unlocked one then flash the RUU for the unlocked version and there you go converted to the USA unlocked version from sprint.
So unlike your saying they are NOT alike, apparently they ARE enough to convert to USA unlocked version. Check out Xda U11 forum the posts are all there so apparently they CAN be converted.
Old 08-30-2017, 04:15   #63 (permalink)
Member: 2750615
Thanks Meter: 4
Originally Posted by xtc2clip View Post
Hi!
I also suffered from the same problem
I successfully M9 its working
HTC 10 and U11 is not working
In my case, the connection between the flex and the phone was not a problem
The file system repair method previously written on the bulletin board did not get better
I was able to use it in U11 in this procedure
1) Connect flex to PC and backup SMART_IO CRD to PC
2) Format the flex with Windows (10) (FAT , Standard allocation)
3) Copy the backed up SMART_IO CRD to the clip
4) In Windows explorer, open the property and check the error in the tool tab
This procedure is not always suitable for everyone
If you can use it without problems with other phones, you should doubt the clip body (filesystem)
The Following User Says Thank You to wpandroidios For This Useful Post:
Old 08-30-2017, 11:21   #64 (permalink)
Member: 2752699
Thanks Meter: 5
can not S-off , please help me
1. Checking phone connectivity...
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem writesecureflag 0
... (bootloader) HTC KEY CARD VERSION: 7
FAILPERMISSION DENY (GT_CONNECT_FAIL)
FAILED (remote: PERMISSION DENY (GT_CONNECT_FAIL))
Execution time is 1(s)
Operation completed!
Releasing adapter.
Request completed
I tried many time.....
The Following User Says Thank You to skybon_hp For This Useful Post:
Old 08-30-2017, 13:06   #65 (permalink)
Member: 2416253
Thanks Meter: 3,757
Process started
Releasing adapter.
Request completed
Hello!
Please make sure PowerAdapter is inserted into the XTC 2 Clip.
Try to remove it and insert again.
This error (GT_CONNECT_FAIL) means there is no connection between clip and the PowerAdapter.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 08-31-2017, 02:55   #66 (permalink)
Member: 2420279
Thanks Meter: 22
Interesting. I stand corrected. I didn't think that was the case.
Old 08-31-2017, 06:37   #67 (permalink)
Member: 2752699
Thanks Meter: 5
Hello!
Thanks for your support and for your info.
After check power adapter and my XTC 2 Clip
I saw a problem.
Point contact of adapter and XTC unlapped when i insert adapter to the XTC slot.
The Following 2 Users Say Thank You to skybon_hp For This Useful Post:
Old 09-01-2017, 10:23   #68 (permalink)
Member: 2578906
Hi,
i have change the new flex and checked it same error message i got it. but desire 530 s-off was successful. please if anyone can help me to fix this issue
thanks
Old 09-01-2017, 10:40   #69 (permalink)
Member: 2578906
Hi!
Hi,
i have change the new flex and checked it but same error message i got it. but desire 530 s-off was successful. please if anyone can help me to fix this issue. i desperately need to flash the phone.
thanks
Old 09-01-2017, 14:57   #70 (permalink)
Member: 2578906
dear team,
i have connect the device and click trusted reboot option first
Process started
Sending oem reboot-download
... OKAY
Execution time is 2(ms)
Waiting for the phone to reboot...
Phone DISconnected
Phone connected [LC75K1001187] *** Fastboot mode
Building connection
Initiating communication
Building connection
Data exchange sequence.
Phone connected
Requesting information from server
Requested sent, waiting 3 seconds for reply...
Processing...
Data exchange completed
Data exchange sequence.....
Building connection
Processing...
Sending oem readimei
... (bootloader) imei: 353491081450581
OKAY
Execution time is 4(s)
Releasing adapter.
Request completed
then i tried to s-off i clicked write security
i got this message
Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage.
Process started
FAILPERMISSION DENY (NOT_FIND_SMART_IO)
FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO))
Execution time is 5(ms)
Releasing adapter.
Request completed
i have not remove the clip from device . but its saying check your flex cable for damage.
flex cable is working
please help me some one
Old 09-01-2017, 17:39   #71 (permalink)
Member: 2416253
Thanks Meter: 3,757
Hello,
Not sure what can cause this situation, but you can do S-OFF without using trusted reboot.
Old 09-01-2017, 18:42   #72 (permalink)
Member: 2350594
Thanks Meter: 5
hello, I repair the imei in HTC U11 and when I enter the operating system it follows the damaged imei, which solutions have, please.
Old 09-01-2017, 22:36   #73 (permalink)
Member: 34549
Thanks Meter: 36
Desire D650h s-off not successfull:
Requested card version not detected, version 6 will be used
Process started
... (bootloader) SecuritySDInit: counter = 4
(bootloader) a17uhl_init_sd, SD card already power on
(bootloader) a17uhl_init_sd, SD card io already power on
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
Building connection
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: 2
(bootloader) erase_grpmult: 96
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
Waiting 3 seconds more...
Processing...
(bootloader) writesecureflag: Permission denied, value 4
OKAY
Execution time is 11(s)
Releasing adapter.
Request completed
Old 09-04-2017, 09:00   #74 (permalink)
Member: 2578906
Hello,
Dear Sir,
who can fix this issue. is there any issue in s-off on htc desire 10 pro ?. if not please help me to fix it. is there any other way to s-off methods available please ?
Old 09-04-2017, 20:50   #75 (permalink)
Member: 2416253
Thanks Meter: 3,757
Dear Sir,
Hello,
Do you have POwerAdapter?
Page generated in 0.38800 seconds with 7 queries
