09-25-2015, 07:42 | #18 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2463787 Status: Offline Thanks Meter: 0 | change network band HTC HTL23 Dear All, I'm a newbie using HTC, i would like to ask is it possible to change network bands on my HTL23 ? I'm going to used it in Indonesia which use 900 Mhz for UMTS and LTE for internet acces. Thank you |
10-02-2015, 04:21 | #21 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2144916 Status: Offline Thanks Meter: 31 | Unlock Desire 626s T-Mobile or Metro PCS Copy files generated XTC2 box in the tab (M9 + / E9 + / 820s / 626s) (The memory of the box XTC2 must be good but if it is not then fix it) Let's continue: The XTC2 box shows these steps and this is where all lose Step 1: With XTC2Clip connected to PC, press the button Desired Corresponding to copy the files to the dip: Copy files for M9 / M9 Sprint Copy files for M9 + / E9 + / Desire 820s > Copy files for Desire 626 (s) < Step 2: Power off the phone. Connect clip to the phone's microSD slot, hold VOLUME UP (NOT usual volume DOWN). And while holding VOLUME UP Press power on button for 5 seconds. The phone will boot into factory test mode. Simplifying: After copying the files generated by XTC2 box (THROUGH Card Reader). disconnect the box, and with the phone off, introduce XTC2 memory, the reader of the phone. Then will do this: press volume up (NOT STOP PRESSING), press power button only five seconds and release it (only the button POWER). Wait a few seconds, almost a minute. The phone will boot into factory test mode (you can not see. Longer lasting one second the work done XTC2 box). That's all (When you turn your phone will say: 1 upgrade 39 but it does, it's because you did wrong) if it does not work to update the firmware of the box with the Client 1.3 XTC2, repair memory. but I assure you it works. tested by me on, HTC Metro PCS and T-Mobile. |
The Following 3 Users Say Thank You to Exa57 For This Useful Post: |
02-19-2016, 00:52 | #22 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
thanks for the instruction i was done and its goes 1 upgrade 39 so i have to redo it again? Last edited by chris2007; 02-19-2016 at 00:58. | |
