09-29-2015, 20:29 | #1 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | XTC 2 Tool 1.11 has been released | Desire 626(s) WHL support and more [29.09.2015] XTC2Tool version 1.11: - Added support for Desire 626s with EWHL firmware (MetroPCS,T-Mobile, etc). - Improved support for M9 Sprint unlock - now the phone will remain unlocked even in S-ON state Please make sure to download latest drivers from our support page: XTC 2 Clip Direct download: http://xtc2.net/downloads/xtc2tool_1.11_setup.exe Previous releases: http://forum.gsmhosting.com/vbb/f961...015-a-1994225/ XTC 2 Tool 1.09 has been released | M9 Sprint easy sim unlock and more [28.08.2015] XTC 2 Tool 1.08 has been released | World First easy HTL23 sim unlock [14.08.2015] XTC 2 Tool 1.07 has been released | World First HTC Bootloader Unlock[07.08.2015] XTC 2 Tool 1.06 has been released [27.07.2015] XTC 2 Tool 1.05 has been released [19.07.2015] XTC 2 Tool 1.04 has been released |
The Following 8 Users Say Thank You to xtc2clip For This Useful Post: |
09-30-2015, 15:21 | #9 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
If you saw the FTM menu then it means that you did not do the "Copy files for 626(s)" procedure. | |
09-30-2015, 15:28 | #10 (permalink) |
Junior Member Join Date: Apr 2009 Location: Reynosa
Member: 1013729 Status: Offline Thanks Meter: 2 | I copy files to sd,put the sd flex on sd slot of the phone (Y cable doesnt work) press vol + and power 5 seconds the screen quicky show a white screen with green letters like diag or something like that and after that ftm menu appear, can you explain i never have a regular 626s only 626s metro |
09-30-2015, 17:11 | #11 (permalink) | |
09-30-2015, 18:11 | #14 (permalink) | |
http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ | |
09-30-2015, 22:07 | #15 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2144916 Status: Offline Thanks Meter: 31 | the box says very clear instructions: Copy files generated XTC2 box in the tab (M9 + / E9 + / 820s / 626s) (The memory of the box XTC2 must be good but if it is not then fix it) Let's continue: The XTC2 box shows these steps and this is where all lose Step 1: With XTC2Clip connected to PC, press the button Desired Corresponding to copy the files to the dip: Copy files for M9 / M9 Sprint Copy files for M9 + / E9 + / Desire 820s > Copy files for Desire 626 (s) < Step 2: Power off the phone. Connect clip to the phone's microSD slot, hold VOLUME UP (NOT usual volume DOWN). And while holding VOLUME UP Press power on button for 5 seconds. The phone will boot into factory test mode. Simplifying: After copying the files generated by XTC2 box (THROUGH Card Reader). disconnect the box, and with the phone off, introduce XTC2 memory, the reader of the phone. Then will do this: press volume up (NOT STOP PRESSING), press power button only five seconds and release it (only the button POWER). Wait a few seconds, almost a minute. The phone will boot into factory test mode (you can not see. Longer lasting one second the work done XTC2 box). That's all (When you turn your phone will say: 1 upgrade 39 but it does, it's because you did wrong) |
