Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 10-23-2015, 10:54   #16 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by zoltar1308 View Post
i download 2 times a firmvare and error of arhive
E:\PN07IMG_M7_UL_L50_SENSE60_MR_HTC_Europe_7.19.40 1.2_Radio_4T.35.3218.16_10.33Q.1718.01L_release_42 1790_signed_2_4.zip: The archive is either in unknown format or damaged
You cannot unpack it, it's encrypted.
You can only flash it.
Old 10-23-2015, 10:54   #17 (permalink)
Member: 380870
Thanks Meter: 159
I will try. Thanks for the reply
Sent from my SM-N920C using Tapatalk
Old 10-23-2015, 10:56   #18 (permalink)
Member: 2416253
Thanks Meter: 4,162
Don't forget to switch phone into RUU mode (use RUU button in XTC 2 Tool), the flashing command is:
fastboot flash zip <filename.zip>
Old 10-23-2015, 10:56   #19 (permalink)
Member: 380870
Thanks Meter: 159
Ok
Old 10-23-2015, 11:19   #20 (permalink)
Member: 380870
Thanks Meter: 159
the m7 is s-off, cid 11111111 bootloader is unlocked, RUU mode and flash via cmd i recive this error
C:\Users\admin\Desktop\300>fastboot flash zip PN07IMG_M7_UL_L50_SENSE60_MR_HTC_E
urope_7.19.401.2_Radio_4T.35.3218.16_10.33Q.1718.0 1L_release_421790_signed_2_4.z
ip
target reported max download size of 1514139648 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 162673659 is not a multiple of t
he block size 4096
sending sparse 'zip' (1478648 KB)...
he block size 4096
he block size 4096
OKAY [ 49.318s]
writing 'zip'...
(bootloader) zip header checking...
(bootloader) shift signature_size for header checking...
FAILED (remote: 32 header error)
finished. total time: 49.519s
Old 10-23-2015, 11:36   #21 (permalink)
Member: 2416253
Thanks Meter: 4,162
ip
he block size 4096
he block size 4096
he block size 4096
OKAY [ 49.318s]
writing 'zip'...
We will check today.
Old 10-23-2015, 11:39   #22 (permalink)
Member: 380870
Thanks Meter: 159
I have to use the terminal from the clip or normal cmd
Old 10-23-2015, 13:32   #23 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
its working for me to enter sapport side
but whyen search for file not found
can u pls upload this file
PDM_CP3_DCG_JB_50_APTG_TW_1.48.500.4_Radio_0.10.W1 249P5.003.9CG.4799_NV_NV_MFG__APTG_1.22_release_38 7393_combined_signed.zip
Old 10-23-2015, 15:08   #24 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
To flash just change name to PN07IMG.zip in HTC ONE M7(other phone other name), copy to sdcard, insert card to phone or Y cable (depent on phone) and just enter hboot screen and phone will be flashed correcly.
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 10-23-2015, 15:56   #25 (permalink)
Member: 380870
Thanks Meter: 159
Thanks for your answers. I will try
Old 10-23-2015, 16:24   #26 (permalink)
Member: 2416253
Thanks Meter: 4,162
Better use normal command line, terminal is not very adapted for long-time commands like flashing.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 10-23-2015, 16:29   #27 (permalink)
Member: 380870
Thanks Meter: 159
I rename the file to PN071IMG.zip and in bootloader mod is show no image or wrong image
Old 10-23-2015, 17:04   #28 (permalink)
Member: 2416253
Thanks Meter: 4,162
It must be PN07IMG.zip, not PN071IMG.zip
Old 10-23-2015, 17:05   #29 (permalink)
Member: 380870
Thanks Meter: 159
But is not the same? ?
Old 10-23-2015, 17:07   #30 (permalink)
Member: 380870
Thanks Meter: 159
I rename without "1" here i not write correct
Page generated in 0.18716 seconds with 9 queries
