Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-07-2017, 19:32   #16 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by Steve-1 View Post
This solution was working fine but now with my new update antivrus even i puas protection still delet it. So pleas i need it in zip format
I know these Antivirus update...you can stop the same and put in Exclusion list the same, ceck carefully New option.
Old 07-07-2017, 19:34   #17 (permalink)
Member: 2501288
Thanks Meter: 328
Where's the problem to uplouding the update in zip format pleas?
Sent from my MHA-L29 using Tapatalk
Old 07-07-2017, 19:37   #18 (permalink)
allumts's Avatar
Member: 1564612
Ok, now stop here please, have just answered P.Manager that Not there's any problem!!!!
Old 07-07-2017, 20:07   #19 (permalink)
Member: 2501288
Thanks Meter: 328
other link for last update 1.31 in zip format
https://drive.google.com/open?id=0B8...UN5SEt1MXI4cFE
Old 07-08-2017, 18:25   #20 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
zip format can't help, as you need to run installer anyway.
We are sorry for problems, but as already said, XTC 2 Clip has no malware inside, it's just the protector, which is used for security.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 07-08-2017, 18:45   #21 (permalink)
Member: 2501288
Thanks Meter: 328
Originally Posted by xtc2clip View Post
Hello,
Hi
I was need in zip format just a temporary solution until found the exact problem. Any way now all work good . Thanks all helper
Old 07-12-2017, 02:08   #22 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 309
Hi
Power adapter will do too old devices like old card or need exchange power adaptor each time when do phones whit old security??
Old 07-12-2017, 12:03   #23 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by bananin View Post
Hi
Hello,
At the moment old devices are not supported, but we will add support a bit later.
Old 07-12-2017, 14:54   #24 (permalink)
Member: 2557992
Sonork: 100.1673157
Thanks Meter: 11
sir, still the problem
1. Checking phone connectivity...
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem writesecureflag 0
... (bootloader) HTC KEY CARD VERSION: 7
Building connection
Initiating communication
Building connection
Data exchange sequence.
Requesting information from server
Requested sent, waiting 3 seconds for reply...
Waiting 3 seconds more...
Processing...
Data exchange completed
FAILPERMISSION DENY (VERIFY_GET_PATERN_FAIL)
FAILED (remote: PERMISSION DENY (VERIFY_GET_PATERN_FAIL))
Execution time is 18(s)
Operation completed!
Releasing adapter.
Request completed
Old 07-12-2017, 18:24   #25 (permalink)
Member: 2416253
Thanks Meter: 4,162
Process started
Building connection
Building connection
Processing...
Releasing adapter.
Request completed
Hello,
Just try again, and I'd recommend you to leave phone on the table/surface, if you will hold it in hands it may influence on the communication process, as flex is very sensitive.
Old 05-08-2018, 07:52   #26 (permalink)
Member: 1946652
Thanks Meter: 14
htc d728w frp unlocking successfilly done by xtc2clip.
__________________________________________________ ________
Starting FRP unlock procedure
Phone detected, reading token...
Token detected successfully
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Removing FRP ...
Done. FRP was removed.
Phone DISconnected.
Page generated in 0.16830 seconds with 8 queries
