02-09-2018, 11:54 | #34 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
http://forum.gsmhosting.com/vbb/12725549-post6.html | |
02-10-2018, 09:52 | #35 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | is process works fine with anybody when we finish first process and check phone will see new imei,s or old |
02-12-2018, 19:06 | #36 (permalink) |
Junior Member Join Date: Nov 2006
Member: 391241 Status: Offline Thanks Meter: 0 | Hi, How to unlock the bootloader with an xtc clip for Htc U11? I need to unlock the bootloader, and the oem point is not included in the settings of the phone, the phone does not start, there is also no RUU for this firmware. Thank you |
02-12-2018, 19:09 | #37 (permalink) | |
Must find same firmware as in your phone with same cid Or u must use power adapter to change cid if phone can boot in download mode Sent from my iPhone using Tapatalk | |
02-12-2018, 19:16 | #38 (permalink) | ||
Member: 391241 Status: Offline Thanks Meter: 0 | Quote:
It is loaded in Download mode and in Recovery but the bootloader is locked, can I change the CID in this state? Quote:
02-12-2018, 19:17 | #39 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | What about zip file Post fastboot info supporter might upload firmware if not available on support Sent from my iPhone using Tapatalk |
02-17-2018, 06:57 | #43 (permalink) |
Crazy Poster Join Date: Apr 2015 Location: Haiti, Delmas 75
Member: 2385265 Status: Offline Thanks Meter: 20 | Hi, i'm using xtc 2 clip the 1.34 version.the message below is the issue i've found, could i have help from someone please?: Sending reboot ftm adb server is out of date. killing... * daemon started successfully * Operation finished Phone DISconnected Phone connected [HT7BF1500176] *** ADB mode Phone DISconnected i don't have access to FTM on the desire 550. i need help please. |
02-17-2018, 18:08 | #44 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2350594 Status: Offline Thanks Meter: 9 | hello, since the reboot of trust is working correctly, now I flash U11_recovery_xtc2.img and I give it a start and it restarts twice and does nothing, when the imei is verified it is not repaired, please help, thanks. |
