Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 02-23-2018, 08:10   #46 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Originally Posted by Victorflorez11 View Post
you know if there is u11 support in oreo for s-off
u11 permanent s-off not supported
Old 02-23-2018, 16:05   #47 (permalink)
Member: 2814281
the u11 supported up to 7.1 but in oreo it did not give me temporary s-off
Old 02-28-2018, 08:08   #48 (permalink)
Registered User
Member: 1382638
Thanks Meter: 5
how to sim unlock T-mobile HTC U11 Life?
Old 03-01-2018, 21:33   #49 (permalink)
Member: 19041
Thanks Meter: 23
Originally Posted by albekill View Post
hello, since the reboot of trust is working correctly, now I flash U11_recovery_xtc2.img and I give it a start and it restarts twice and does nothing, when the imei is verified it is not repaired, please help, thanks.
hi i have this some problem
Old 03-04-2018, 08:33   #50 (permalink)
Member: 2557992
Sonork: 100.1673157
Thanks Meter: 11
Sir, trust reeboot is working correctly, but when I flash U11_recovery_xtc2.img and I give it a start , the phone restarts twice and do nothing, in "fastboot getvar all" the imei is verified but it is not repaired, so i reflash de IMG. recovery ( the official posted here) and can´t enter in recovery mode never, always send me direct to the OS, is there something wrong with the recovery IMG. or it isn´t support yet correctly? Can you help me please sir, i need to repair imei and unlock the phone.
Thank´s in advanced
B.R.
Old 03-04-2018, 18:16   #51 (permalink)
Member: 2416253
Thanks Meter: 4,162
Please try this recovery:
https://xtc2.net/downloads/U11_recovery_xtc2_new.zip
Make sure to delete old recovery and use this new one.
Old 03-09-2018, 14:42   #52 (permalink)
Member: 2717418
Red face htc u11 error repair imei
hola tego una semana ya intentando reparar el imei de un htc u11 y ambos procedimientos no me sirven de nada, todo da error ya somos muchos con problemas, podrian montar un video explicando y haciendo el procedimiento, por favor
Old 03-09-2018, 14:47   #53 (permalink)
Member: 2202707
Sonork: whatsapp +59170073722
Thanks Meter: 212
amigo aquí solo se escribe en ingles
friend here is only written in English
Old 03-09-2018, 14:58   #54 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
explain errors in english please with logs if possible or screenshots
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 03-10-2018, 14:25   #55 (permalink)
Member: 2717418
does not repair imei with any of the two steps, in the case of reapir imei simlock, when you give star the phone restarts and keeps turning off and restarting all the time, does not enter any recovery only keeps turning off and turning on, the recovery will lower them of the xtc2clip master but they do not do anything just reboots and already a dark screen and that's it
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_ocndugl
(bootloader) version: 1.0
(bootloader) max-download-size: 1560800000
(bootloader) serialno: FA77E1802473
(bootloader) slot-count: 0
(bootloader) current-slot:
(bootloader) imei: 356133082643924
(bootloader) version-main: 2.33.401.10
(bootloader) boot-mode: download
(bootloader) version-baseband: 8998-002772-1711161638
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PZC30000
(bootloader) cid: HTC__034
all:
Execution time is 0(ms)
Reading CID information
... (bootloader) cid: HTC__034
OKAY
Execution time is 1(s)
Reading MEID information
... (bootloader) meid:
OKAY
Reading IMEI1 information
... (bootloader) imei: 356133082643924
OKAY
Execution time is 15(ms)
Reading IMEI2 information
... (bootloader) imei2: 356133082643932
OKAY
Reading secure flag information
... (bootloader) Device security level S-ON, reboot count 0
OKAY
Execution time is 46(ms)
Reading serial number information
... (bootloader) Device Serial No. is FA77E1802473
OKAY
Read information completed.
s-off no work
1. Checking phone connectivity...
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem writesecureflag 0
... (bootloader) HTC KEY CARD VERSION: 7
FAILPERMISSION DENY (DENY)
FAILED (remote: PERMISSION DENY (DENY))
Operation completed!
Releasing adapter.
Request completed
trustedreboot reboot ok correct but wreatting dont reapir imei error
Process started
Sending oem writeimei2 354198752031488
... (bootloader) [ERR] Command error !!!
OKAY
Releasing adapter.
Request completed
Old 03-10-2018, 14:28   #56 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
you have write this recovery http://forum.gsmhosting.com/vbb/12999908-post51.html
or other ?
Old 03-10-2018, 14:43   #57 (permalink)
Member: 2717418
I have downloaded tods the recovery posted by the master xtc2clip,
and that you recommended me to download it 3 times
and remains the same without entering the recovery when pressing star
Old 03-10-2018, 19:41   #58 (permalink)
Member: 2717418
good afternoon sir productor manager xtc2clip, I want to ask you a question, I have 2 xtc2clip a power adapter and 4 new flex newly purchased, I do the repair process imei simlock and it does not work, I think that when the software says look at your cell, the recovery will appear written or something like that. but not only turns on and off in the message of the bootloader ..... and the other step does not work either, everything gives error (Sending oem writeimei2 354198752031488
... (bootloader) [ERR] Command error !!!,) could you tell me if the xtc and the power do not work in oreo. since none of the two xtc nor the flex could be with the error, I have already tried in different computers and it does not matter. then I thank you tell me if it is that the oreo won the current system of the poweradapter .. I have two weeks trying and nothing I have done other tel and all good but the u11 is unbreakable ....... thank you very much your answer
Old 03-24-2018, 15:54   #59 (permalink)
Member: 2717418
good morning, waiting for the producer manager of xtc2clip to respond a while ago and not telling me anything, I think that for more than a question you should think that if I do it to you it is because I buy your tools friend. if you are going to have a support you should attend to your clients, at least tell the client and received your question, some day in the year I give you an answer, but you do not say anything, I know that some here help others and I thank that , 'But my question was straight to you, I think it is safer that the chimera tool people first find the imei repair for the u11 with oreo, or at least they will answer me if I ask them the question. Anyway, it's just a recommendation to the manager
thank you very much if you see the message
Old 03-25-2018, 08:18   #60 (permalink)
Member: 2557992
Sonork: 100.1673157
Thanks Meter: 11
Where do you from? ( de dónde eres amigo) if youre from mexico i can help you, i repaired mine with Telcel report !
Page generated in 0.24807 seconds with 8 queries
