xtc Cannot obtain server address Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Error: Cannot obtain server address. Please try again later - please check your firewall settings also. |
Check your internet connection ... Disconnect and reconnect Faced such issues before |
i cant active my clip also when will be come to reply with xtc support then can know the status of server |
The server is working fine, kindly make sure you are using client version 1.4. As to the topic starter problem - kindly make sure you can access http://xtc2.net in your browser please. All servers are online and running at the moment: - Web server - Download (support server) - Activation server - XTC 2 Tool processing server |
so i did not add any clain install pls guide me win 10 installer procedure i just install xtc clip only setup |
The only thing that can prevent XTC 2 Tool from accessing internet is your built-in Windows firewall. Try to contact me on Skype: xtc2clip, I can try to check via Teamviewer tomorrow. |
thanks |
I can't activate my xtc. Server not found? |
