Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 02-04-2019, 12:31   #1 (permalink)
Member: 1014618
Sonork: 100.1637137
Thanks Meter: 74
xtc Cannot obtain server address
Starting FRP unlock procedure
Phone detected, reading token...
Token detected successfully
Checking server connection...
Error: Cannot obtain server address. Please try again later - please check your firewall settings also.
Old 02-04-2019, 20:22   #2 (permalink)
Member: 2367649
Thanks Meter: 6
Check your internet connection ...
Disconnect and reconnect
Faced such issues before
Old 02-05-2019, 04:12   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 631
Originally Posted by cole00 View Post
check your internet connection ...
faced such issues before
xtc clip server down totally
i cant active my clip also
when will be come to reply with xtc support then can know the status of server
Old 02-05-2019, 11:38   #4 (permalink)
Member: 2416253
Thanks Meter: 3,768
Hello!
The server is working fine, kindly make sure you are using client version 1.4.
As to the topic starter problem - kindly make sure you can access http://xtc2.net in your browser please.
All servers are online and running at the moment:
- Web server
- Download (support server)
- Activation server
- XTC 2 Tool processing server
Old 02-06-2019, 04:09   #5 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 631
Originally Posted by xtc2clip View Post
Hello!
- Web server
- Activation server
i had change to win7 to 10 64 bit
so i did not add any clain install
pls guide me win 10 installer procedure
i just install xtc clip only setup
Old 02-06-2019, 19:31   #6 (permalink)
Member: 2416253
Thanks Meter: 3,768
This is enough, you don't need anything else.
The only thing that can prevent XTC 2 Tool from accessing internet is your built-in Windows firewall.
Try to contact me on Skype: xtc2clip, I can try to check via Teamviewer tomorrow.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 02-07-2019, 06:05   #7 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 631
problem solved by claint 1.4
thanks
Page generated in 0.24555 seconds with 7 queries
