02-23-2016, 14:36 | #3 (permalink) |
Major Poster Join Date: May 2013
Member: 1950641 Status: Offline Thanks Meter: 14 | clip registered: yes email activated: yes clip activated: yes clip upgrade availabe: no xtc activation complete m9 s-off error Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 35722606...... (bootloader) version-main: 3.35.401.12 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U11440792_97.00.51203G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: HTC__M27 Execution time is 10(ms) all: Reading secure flag information ... (bootloader) Device security level S-ON Execution time is 60(ms) OKAY Reading CID information ... (bootloader) cid: HTC__M27 Execution time is 10(ms) OKAY Reading MEID information ... (bootloader) meid: Execution time is 10(ms) OKAY Read information completed. Removing FRP protection Rebooting to bootloader mode... Phone DISconnected Phone connected [FA569YJ01254] *** Fastboot mode WARNING: It seems that your phone is not S-OFF! Please do S-OFF first in case of error Trying method #2016 SUCCESS. FRP protection was removed direct mode commands Sending oem writesecureflag 0 Execution time is 10(ms) ... FAILunknown command FAILED (remote: unknown command) Operation finished |
02-23-2016, 22:23 | #8 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Later can work in these Old phones w/o problem in Legacy mode if fail normal mode. BR allumts | ||
The Following User Says Thank You to allumts For This Useful Post: |
02-24-2016, 10:04 | #9 (permalink) |
Member: 1950641 Status: Offline Thanks Meter: 14 | change xtc flex sd change microsd reader and m9 connected xtc select direcd mode Sending oem reboot-download Execution time is 0(ms) ... OKAY Operation finished Phone DISconnected Sending oem writesecureflag 0 Execution time is 899(ms) ... FAILPERMISSION DENY (SELECT_APPLET_FAIL) FAILED (remote: PERMISSION DENY (SELECT_APPLET_FAIL)) Operation finished Img 8364 - H?zl? Resim |
02-24-2016, 11:57 | #10 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ok, you have need of read carefully Here: http://forum.gsmhosting.com/vbb/f961...6-etc-2022417/ Ceck also Y cable and if Smart card is inserted correct...seem of yes but you need of Insert First Flex in Slot Sd Card and later put in Download mode, (recovery). For Direct Mode. Otherwise can do in Sd Mode and is more easy. BR allumts |
02-24-2016, 19:28 | #11 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
02-29-2016, 12:50 | #14 (permalink) |
Member: 1950641 Status: Offline Thanks Meter: 14 | thanks for help. box working 1- update xtc clip 2- repair sd card image htc one x s-off cid 11111 ok http://i.hizliresim.com/d32XzV.jpg htc sense xl s-off ok cid1111 ok http://i.hizliresim.com/LA4QPG.jpg http://i.hizliresim.com/1vkNYj.jpg |
The Following User Says Thank You to vTs Teknik For This Useful Post: |
