xtc clip2 after format with pc 1 Attachment(s) after format clip with xtc clip2 write this file to clip sucessfull image2015.img show error when i perform any opertion disk open sucess full in computer when i try connect with xtc2client_1.4 show this error picture below |
Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) a52dtul_init_sd, SD card already power on (bootloader) a52dtul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 1088882688 (bootloader) erase_grpmult: 49152 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) writesecureflag: Permission denied, value 8 OKAY Execution time is 4(s) Operation finished when i try to excute any opertaion this error come plz help thnx |
Try repair clip again if fails change flex and try again Sent from my iPhone using Tapatalk |
i change flex 3 new flex still same |
any solutio plz help team |
if clip is not detected by xtc2clipclient that means flex or card reader problem in rare case could be windows problem try repair process on other pc |
Hello, You need re-activation, please PM me your clip ID or run XTC 2 Client on your clip. |
Hi, I have problem with xtc 2 clip, I have about 1 week without being able to use it losing a lot of money, with more than 200 teams to solve of clients and of wholesale sales. FAILPERMISSION DENY (DECREASE_CYCLE_FAIL) FAILED (remote: PERMISSION DENY (DECREASE_CYCLE_FAIL)) DONGLE SERIAL NUMBER 90038408 |
