Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 01-13-2018, 17:42   #1 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Thanks Meter: 136
xtc clip2 after format with pc
after format clip with xtc clip2 write this file to clip sucessfull image2015.img show error when i perform any opertion
disk open sucess full in computer
when i try connect with xtc2client_1.4 show this error picture below
Old 01-13-2018, 17:53   #2 (permalink)
Member: 210880
Sonork: 100.1577765
Thanks Meter: 136
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 2
(bootloader) a52dtul_init_sd, SD card already power on
(bootloader) a52dtul_init_sd, SD card io already power on
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: 1088882688
(bootloader) erase_grpmult: 49152
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986
(bootloader) writesecureflag: Permission denied, value 8
OKAY
Execution time is 4(s)
Operation finished
when i try to excute any opertaion this error come plz help thnx
Old 01-13-2018, 18:53   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 855
Try repair clip again if fails change flex and try again
Sent from my iPhone using Tapatalk
Old 01-15-2018, 12:29   #4 (permalink)
Member: 210880
Sonork: 100.1577765
Thanks Meter: 136
i change flex 3 new flex still same
Old 01-20-2018, 12:56   #5 (permalink)
Member: 210880
Sonork: 100.1577765
Thanks Meter: 136
any solutio plz help team
Old 01-20-2018, 16:37   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 855
if clip is not detected by xtc2clipclient that means flex or card reader problem
in rare case could be windows problem
try repair process on other pc
Old Yesterday, 14:48   #7 (permalink)
Member: 2416253
Thanks Meter: 3,164
Hello,
You need re-activation, please PM me your clip ID or run XTC 2 Client on your clip.
Page generated in 0.14919 seconds with 8 queries
