03-22-2016, 13:02 | #2 (permalink) | |
Banned Join Date: Nov 2012 Location: unknown
Member: 1837438 Status: Offline Sonork: unknown Thanks Meter: 659 | Quote:
IMPORTANT: How to repair filesystem after format, etc | |
03-22-2016, 22:19 | #3 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | Sometimes this happens because the SD Flex Cable is not properly inserted into the SD slot. What kind of phone are you working with. I know the HTC ONE M8's need the flex cable to be in that "sweet spot". Try unplugging and re plugging cable a bunch of times make sure it is in all the way. Try powering on your phone, go to the SD card storage settings and put in your Flex Cable. You should see SD storage size detect, then you can power off phone and unlock |
The Following User Says Thank You to GTrader For This Useful Post: |
03-23-2016, 18:07 | #8 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2546748 Status: Offline Thanks Meter: 0 | It's the WIN disk that wont work, this was supposed to be an easy plug and play device what else can I try before I send it back for a refund and explain to my boss that it wont work? |
03-23-2016, 18:17 | #9 (permalink) |
Member: 2546748 Status: Offline Thanks Meter: 0 | Surely it's me giving the tool the information ie IMEI number for the unlock code isn't it? I can't help but feel like I'm trying to fix something that should have just worked. |
03-23-2016, 18:32 | #10 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
You should not explain anything to your boss, you should learn how to use a tool, we have around 10k customers, and for these people "it works", strange, don't you think so? So will you finally be so kind to explain WHICH MODEL are you trying to unlock (or maybe, S-OFF), and which stage do you get this error? | |
The Following 3 Users Say Thank You to xtc2clip For This Useful Post: |
