07-01-2015, 17:26 | #16 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
07-01-2015, 17:34 | #18 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Yes I see it's Ruby model. I don't have it on hands now so I can't tell anything. Can we get back to T6 One Max? I have never seen a clip that is detected on a PC but will not be detected in the phone. Can you insert any regular SD card to make sure the slot is working? Can you confirm you tried the clip on both phones just now and it doesn't work even after repair? If so, you may contact your dealer for replacement. You can keep the card and replace the clip only. |
07-01-2015, 17:40 | #19 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: USA
Member: 1361178 Status: Offline Thanks Meter: 95 | Quote:
tried in 4 phones m7, m8, htc one max sprint and the las one htc amaze tmobile, i don't have any other htc now but i will try to get one and i will post results thanks!! | |
07-01-2015, 17:45 | #20 (permalink) | |
You do use the sd-slot right, not the Y-cable (except the M7 which has no sd-slot) | |
07-01-2015, 18:45 | #23 (permalink) | |
htc amaze sd card done with sd card slot and direct mode maybe problem is card reader but i tried many sd card reader different brands, where can buy tested sd card reader and Y-cable? thanks!! | |
07-01-2015, 18:51 | #24 (permalink) | |
It can't damage the cable if you will do everything carefully So you have tried all phones using Y-cable? Your Y-cable can be damaged/wrong as well. We have produced a stock of Y-cables and now shipping to our dealers. As to sd-readers, I'm now using Kingston like this: http://www.amazon.co.uk/Kingston-Gen.../dp/B0028R3NCU | |
07-01-2015, 19:12 | #25 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | @Customers Be carefull when you buy these readers you must have to buy the original as i found in many cases peoples buy same look but its not original and peoples bought this and getting same issues because its not real and they use old IC and still got trouble Regards, GsmEasy |
07-01-2015, 19:21 | #26 (permalink) | |
07-01-2015, 19:24 | #27 (permalink) | |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | Quote:
