07-13-2016, 19:30 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 238466 Status: Offline Thanks Meter: 18 | xtc2clip not working? Code: Sending oem writeimei 353450065074809 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) a11ul_init_sd, SD card already power on (bootloader) a11ul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -1921008425 (bootloader) erase_grpmult: -1921008452 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] Javacard reset response timeout C= 1000. (bootloader) writeimei: Permission denied, value 2 OKAY Execution time is 4(s) Operation finished Code: Sending oem clearsimlocktype ... (bootloader) [ERR] Command error !!! OKAY Execution time is 4(ms) Operation finished |
