04-05-2019, 15:02 | #1 (permalink) |
Crazy Poster Join Date: Aug 2017
Member: 2743735 Status: Offline Thanks Meter: 0 | Y-Cable and HTC One M7 Question imgur (dot) com /a/I1H09yp |
04-05-2019, 19:40 | #3 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
What do you mean by 'not connect'? You cannot use direct mode or any other PC-related modes while using Y cable. Your phone will NOT be detected by PC in this mode. You should use 'sim-lock' menu in Hboot to S-OFF first. Then you can connect phone back to PC and perform other desired operations. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
04-10-2019, 17:55 | #4 (permalink) |
Member: 2743735 Status: Offline Thanks Meter: 0 | Okay, what should I be doing?? I have a HTC One M7 Sprint phone. I tried to do the sprint unlock option but it says for M7 I need to do s-off. How do I do S-off without an SD card port? Please tell me specific instructions because I'm unable to find it. |
04-10-2019, 19:22 | #5 (permalink) | |
Sorry for confusion. You'll need a special cable called Y-cable for models without SD slot, like M7. It's not included with XTC 2 Clip, but you can make it yourself, if you have basic soldering knowledge. | |
04-11-2019, 15:40 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | use sd mode tab for s-off select only s-off than insert clip to sd card reader and connect it to y-cable than connect y-cable to phone in powered off give power to y-cable and power up phone holding volume down button select simlock option on screen |
04-17-2019, 20:48 | #14 (permalink) |
Junior Member Join Date: May 2018
Member: 2838346 Status: Offline Thanks Meter: 0 | first of all, id like to thank mr xtc2clip for hands down the most amazing complete tool to service a specific brand I have ever seen, I recently came across 150 htc phone and right away purchased the clip, UNBELIEVABLE PRODUCT, the best "BOX" tool I have, much easier than doing this on your own, all the scripts are all prewritten and avail at the push of a button, well worth the cost, I alsmost want to buy newer htcs for fun but I have them up to the m9 I believe I may have a 10 im not sure, slight learning curve as with any box, but the guy provides amazing support, ok to the guy with the m7 issue you need to go to the sd tab and hook the box up directly to the computer, save the cid to 111111 and then security to s-off and then hit save to clip, then remove the clip and attach it to the y adapter, and a wall plug did not work for me, btw I had to use a computer, second problem is that only one specific sd card reader worked for me which they have at the walmarts in my area I don't even know if you have walmarts where you are but it looks kind of like a light bulb shape and is sandisk brand and comes with the sandisk sd card in certain packs, all the other ones did not work, these are all steps you must follow for this phone finally, im having server issues again, is this just me or everyone? thanks also, Mr Xtc2Clip, if you ever plan to do a different brand development please let me know thanks |
04-18-2019, 10:18 | #15 (permalink) | |
Thank you very much for your kind words! As to the server, I don't see any problems, can you please tell me, which server do you mean? We have download server for flash files, activation server and regular server for XTC 2 Tool. Thanks. | |
