11-23-2016, 18:20 | #1 (permalink) |
Junior Member Join Date: Apr 2003 Location: Taiwan
Member: 25981 Status: Offline Thanks Meter: 13 | Asus_z00vd read info & ff POPUP MTK EMI SETTING Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM14 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x0000000040000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483847316505 CHIP : MT65800000 CPU ID : EMMC ID : 90014A483847316505 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Hynix_H8G1e Boot Information completed. Reading Project Property ... Brand : asus Phone Model : ASUS_Z00VD Android Ver : 5.1 CPU/Processor : MT6580 MTK Project ver: WW_Phone-12.1.0.51-20160825 SW Version : WW_Phone-user 5.1 LMY47I WW_Phone-12.1.0.51-20160825 release-keys Action completed Time taken : 00:00:27 Reconnect Battery/USB Cable CS-Tool Ver 1.50.2 power off Phone ,hold volume down button , Insert usb cable Action : Read Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM14 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x0000000040000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483847316505 CHIP : MT65800000 CPU ID : EMMC ID : 90014A483847316505 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Hynix_H8G1e Read Hardware Information is done. usb switching to high speed ... New Port: COM15 ......ok switch done. Reading Project Property ... done. Making dir: D:\CSTOOL\MT6580_ASUS_Z00VD_Android5.1_WW_Phone-user 5.1 LMY47I WW_Phone-12.1.0.51-20160825 release-keys_20161124_004841\...[ok] Reading preloader ......ok New EMI config is detected, auto added it to User Database, cnt=3 Saved to: D:\CSTOOL\CS-Tool_MainSoftware_v1.50.2\CST_MainSoftware\private \db\emi\ Reading nvram ......ok Reading lk ......ok Reading boot ......ok Reading recovery ......ok Reading logo ......ok Reading secro ......ok Reading system ......ok Reading cache ......ok Reading userdata ......ok All done. Files saved to: D:\CSTOOL\MT6580_ASUS_Z00VD_Android5.1_WW_Phone-user 5.1 LMY47I WW_Phone-12.1.0.51-20160825 release-keys_20161124_004841\ Action completed Time taken : 00:08:56 Reconnect Battery/USB Cable CS-Tool Ver 1.50.2 Created: 2016/11/24 上午 12:57:12 |
The Following User Says Thank You to pcphone For This Useful Post: |
