08-16-2016, 05:09 | #46 (permalink) |
Freak Poster Join Date: Dec 2008 Location: cebu city
Member: 920138 Status: Offline Thanks Meter: 97 | im try to connect the phone used boot 1 2 3 4 but fail Action : Read Info Boot : SC7731_SDRAM4-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM38) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... Action completed Time taken : 00:00:14 Reconnect Battery/USB Cable CS-Tool Ver 1.48 |
08-16-2016, 09:04 | #47 (permalink) | |
No Life Poster Join Date: Jun 2015 Location: Hongkong
Member: 2409100 Status: Offline Sonork: 100.1667267 Thanks Meter: 3,757 | Quote:
your phone hardware is diffrent than the 4 boots. please post model and brand , also if you have orginal firmware , please give a link to donwload | |
08-16-2016, 10:45 | #50 (permalink) | |
No Life Poster Join Date: May 2006 Location: Mountains
Member: 276322 Status: Offline Thanks Meter: 293 | Quote:
BQ 7008G............. No factory firmware there are other options for Boot? I'll check | |
08-16-2016, 11:01 | #52 (permalink) | |
Code: Action : Read PAC Boot : SC7731_sign-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM34) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... Action completed Time taken : 00:00:16 Reconnect Battery/USB Cable CS-Tool Ver 1.48 Code: Action : Read PAC Boot : SC7731_SDRAM2-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM34) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... Action completed Time taken : 00:00:15 Reconnect Battery/USB Cable CS-Tool Ver 1.48 Created: 16.08.2016 12:29:11 Action : Read PAC Boot : SC7731_SDRAM3-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM34) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... Action completed Time taken : 00:00:19 Reconnect Battery/USB Cable CS-Tool Ver 1.48 Created: 16.08.2016 12:29:56 Action : Read PAC Boot : SC7731_SDRAM4-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM34) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... Action completed Time taken : 00:00:18 Reconnect Battery/USB Cable CS-Tool Ver 1.48 Created: 16.08.2016 12:30:37 | |
08-16-2016, 11:06 | #53 (permalink) | |
08-16-2016, 15:38 | #57 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | This update is not working. I am trying to READ FLASH from working Telefunken TELC-73GIQ 7" tablet. Always fails at 1%. Read file as PAC is grey,cannot select. Quote:
08-16-2016, 15:41 | #58 (permalink) | |
1A. if not working . you need to search something in forum , why not working for you . instead of writing this update not work 2. learn how to use it and read full history updates about Boots what we write and notes 3. anyway . try the SC7731_SDRAM2-eMMC Boot and post Result | |
08-16-2016, 16:26 | #59 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1185384 Status: Offline Thanks Meter: 17 | Dump scatter.txt only / Save scatter.txt file or something like this. Also we need build.prop editor. Some firmware have special characters (* # @ in "ro.build.display.id" "ro.product.model" "ro.product.name" then I can't read the firmware, but if I can edit phone properties then I can read the firmware and make nv backup. Example: ro.build.display.id=BLU_S470a_V13_GENERIC_17-04-2015:04_55 The ":" symbol if a wrong character in the name of backup file. Last edited by uikand; 08-16-2016 at 16:32. |
