11-04-2016, 06:31 | #37 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Action : Fix Unknow BB Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM3 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6583 CPU_SW: 0001 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Tips 1: In case some phone required to hold bootkey to enter download boot mode Tips 2: SecureBoot phone found, According to the brand, Select the supported sign DA from boots list and try again. Action completed Time taken : 00:00:07 Reconnect Battery/USB Cable CS-Tool Ver 1.50.2 |
The Following User Says Thank You to bijoychowdry For This Useful Post: |
11-04-2016, 06:35 | #38 (permalink) |
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Action : Fix Tool DL image fail Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM17 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... ID: 110100303034474530 Error: failed to init DRAM ?. Error: 0xef [ReadInfo]. Action completed Time taken : 00:00:28 Reconnect Battery/USB Cable CS-Tool Ver 1.50.2 |
11-06-2016, 09:07 | #41 (permalink) |
Registered User Join Date: Nov 2006 Location: philipines
Member: 387616 Status: Offline Sonork: 100.1647857 Thanks Meter: 14 | Please activate my dongle....... |
11-06-2016, 18:47 | #42 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2402620 Status: Offline Thanks Meter: 0 | la instale el primer dia y me funciono como 3 horas al volver a conectar no me conecta me dice conectar dongle y resetear software formatie la pc cuando le doy abrir se cierra el programa me arrepiento de comprar la CS-TOOL PRIMERA DONGLE QUE ME DA TANTOO PROBLEMAS!!!!! necesito AYUDAAAAAA install it on the first day and I worked about 3 hours to reconnect me not connecting you tell me connect dongle and reset software formatie the pc when I open it closes the program I regret buying the CS-TOOL FIRST DONGLE THAT GIVES ME Tantoo PROBLEMS!!!!! I need AYUDAAAAAA |
11-07-2016, 10:43 | #43 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82236 Status: Offline Thanks Meter: 583 | Support ... please help me C S TOOL error Dear sir i am getting the following error in my C S Tool since 2 days. send + Receive error. ISO7816 error 0x6985 ( command not allowed.Conditions of use not satisfied ) Thanking you |
