08-24-2016, 11:01 | #3811 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Samsung g530h imei repair done Code: Action : Android Repair IMEI(DownloadBoot Mode) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM11 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034474530 CHIP : MT65720000 CPU ID : EMMC ID : 110100303034474530 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_004GE0 Read Hardware Information is done. Checking imei ... new imei1: 351209098756358 new imei2: 351209079857639 Repairing Imei... Verify Required... Updating NVDATA... Checking CRC: NVRAM ...ok all done ... Action completed Time taken : 00:00:41 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
08-24-2016, 11:02 | #3812 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Samsung g360h write flash done Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM103 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x0000000020000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. usb switching to high speed ... New Port: COM109 ......ok switch done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:04:06 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
08-24-2016, 11:03 | #3813 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile a290 write flash done Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM11 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.65GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:03:34 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
08-24-2016, 11:03 | #3814 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile a300 write flash done Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM11 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Load File : F:\CHINA\PIC NEW\TESTED\A300 Q MOBILE OK MTK6572_1403021306\MTK6572_1403021306.bin Image Size: 0x00000000A00005F8 Programming Flash Image... Programming Flash Image Completed. Action completed Time taken : 00:10:06 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
08-24-2016, 11:04 | #3815 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile a120 write flash done Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM209 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Downloading fat ......ok Updating rom info ......ok All done. Action completed Time taken : 00:03:22 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
08-24-2016, 11:11 | #3816 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile x6i 3g remove pattern done Code: Action : Format / Reset Boot : SC7715-NAND Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM91) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 115200 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 7715 SC Boot Mode : 7715A00000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC7715 CPU ID : 7715A000 NAND ID : 009800BC90660076906676 NAND Size: 512MB NAND Name: NAND_TYBC0A111236KC512 Boot Information completed. Loading CST Boot image to RAM... The CST Boot runs normally. Auto formatting... Format Done. Action completed Time taken : 00:00:38 Reconnect Battery/USB Cable CS-Tool Ver 1.48 THANKS TO CS-TOOL |
08-24-2016, 11:12 | #3817 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile x2 music hang logo done Code: Action : Format / Reset Boot : SC7715-NAND Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM91) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 115200 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 7715 SC Boot Mode : 7715A00000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC7715 CPU ID : 7715A000 NAND ID : 009800BC90660076906676 NAND Size: 512MB NAND Name: NAND_TYBC0A111236KC512 Boot Information completed. Loading CST Boot image to RAM... The CST Boot runs normally. Auto formatting... Format Done. Action completed Time taken : 00:00:42 Reconnect Battery/USB Cable CS-Tool Ver 1.48 THANKS TO CS-TOOL |
08-24-2016, 12:29 | #3818 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | HAIER W716 HANG ON LOGO RECOVRY DONE BY FLASHING WITH THE GREAT CS-TOOL Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM133 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... New id found, testing... Done. Size=0x0000000020000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 45010053454D303447 CHIP : MT65720000 CPU ID : EMMC ID : 45010053454D303447 EMMC Size: 4GB, usable capacity: 3,69GB EMMC Name: eMMC_Sandisk_SD7DP24F_4G Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:13:31 Reconnect Battery/USB Cable CS-Tool Ver 1.42.1 |
08-25-2016, 10:55 | #3819 (permalink) |
No Life Poster Join Date: Sep 2011 Location: IN_YOUR_HEART
Member: 1661953 Status: Offline Sonork: 100.1666694 Thanks Meter: 1,377 | g530 samsung clone write ff done with cs tool g530 samsung clone write ff done with cs tool Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM23 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 7001004D4D43303447 CHIP : MT65720000 CPU ID : EMMC ID : 7001004D4D43303447 EMMC Size: 4GB, usable capacity: 3.55GB EMMC Name: eMMC_Kingston_KE4CN2L2HA8A2A Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. New EMI config is detected, auto added it to User Database, cnt=4 Saved to: C:\CS-Tool\CST_MainSoftware\private\db\emi\ Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:02:50 Reconnect Battery/USB Cable CS-Tool Ver 1.48 |
08-25-2016, 11:18 | #3820 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile x30 write ff with cs-tool Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM11 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447326111 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447326111 EMMC Size: 4GB, usable capacity: 3.65GB EMMC Name: eMMC_Hynix_H4G2a Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:03:54 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
08-25-2016, 11:21 | #3821 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile x1 write flash done Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM47 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6571 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 1501004E3958524D42 CHIP : MT65710000 CPU ID : EMMC ID : 1501004E3958524D42 EMMC Size: 1GB, usable capacity: 1.75GB EMMC Name: eMMC_Samsung_N9XRMB Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:03:40 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
08-25-2016, 11:31 | #3822 (permalink) |
Member: 1661953 Status: Offline Sonork: 100.1666694 Thanks Meter: 1,377 | QMobile A900i write ff done with cs tool Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM23 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6582 CPU_SW: 0001 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 1501004B3758564D42 CHIP : MT65820000 CPU ID : EMMC ID : 1501004B3758564D42 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Samsung_K7XVMB Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading ebr2 ......ok Downloading spdata ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Downloading fat ......ok Updating rom info ......ok All done. Action completed Time taken : 00:05:00 Reconnect Battery/USB Cable CS-Tool Ver 1.48 |
08-25-2016, 11:34 | #3823 (permalink) |
Member: 1661953 Status: Offline Sonork: 100.1666694 Thanks Meter: 1,377 | QMobile A300 write ff done with cs tool Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM23 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Downloading fat ......ok Updating rom info ......ok All done. Action completed Time taken : 00:04:21 Reconnect Battery/USB Cable CS-Tool Ver 1.48 |
08-25-2016, 11:40 | #3824 (permalink) |
Member: 1661953 Status: Offline Sonork: 100.1666694 Thanks Meter: 1,377 | QMobile S1 write ff done with cs tool Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM23 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6582 CPU_SW: 0001 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483847316505 CHIP : MT65820000 CPU ID : EMMC ID : 90014A483847316505 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Hynix_H8G1e Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:05:06 Reconnect Battery/USB Cable CS-Tool Ver 1.48 |
08-25-2016, 11:45 | #3825 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Gfive smart 2 write flash done Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM11 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447326111 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447326111 EMMC Size: 4GB, usable capacity: 3.65GB EMMC Name: eMMC_Hynix_H4G2a Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:02:54 Reconnect Battery/USB Cable CS-Tool Ver 1.47.1 THANKS TO CS-TOOL |
