12-24-2017, 07:43 | #5296 (permalink) |
Product Supporter Join Date: Jul 2015 Location: pk
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile K135 SPD6531 On Off Auto Format Done Bt CS-Tool QMobile K135 SPD6531 On Off Auto Format Done Bt CS-Tool Br FactoryFilePak CS-Tool Team |
The Following 3 Users Say Thank You to FactoryFilePak For This Useful Post: |
12-24-2017, 12:16 | #5297 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Samsung Galaxy J7 Prime MT6580 Read Factory firmware Done By CS-Tool Samsung Galaxy J7 Prime MT6580 Read Factory firmware Done By CS-Tool Br FactoryFilePak CS-Tool Team |
The Following 2 Users Say Thank You to FactoryFilePak For This Useful Post: |
12-24-2017, 12:27 | #5298 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile E50 V3 MT6261 Read Code Done By CS-Tool QMobile E50 V3 MT6261 Read Code Done By CS-Tool Code: Action : Read Codes Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM3 ] Connecting... Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Connection Done. Read CPU Info... CPU_ID: 6261 CPU_SW: CB01 CPU_HW: 8000 Switching to Meta Mode... Waiting for mete ack... handshake protocol is done. Reading ... password: 51214 password: 0012 password: 0000 Action completed Time taken : 00:00:33 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 Br FactoryFilePak CS-Tool Team |
12-26-2017, 13:33 | #5299 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | gionee a1 plus frp unlock done -:) Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM9 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 0551 CPU_SW: 0001 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Getting connection agent statusreloader Send boot2 ... Receive SYNC signal, Boot2 runs normally. Getting RAM info ... SRAM: type[0x2] base_address[0x200000] size[0x50000] DRAM: type[0x1] base_address[0x40000000] size[0x80000000] Getting H/W info ... CHIP : MT6757 CPU ID : EMMC ID : 150100444836444D420536B6C8504401 EMMC Size: 64GB, usable capacity: 58.25GB EMMC Name: eMMC_Samsung_DH6DMB Boot Information completed. Reading Project Property ... Brand : GIONEE Phone Model : A1 Plus Android Ver : 7.0 CPU/Processor : MT6757 MTK Project ver: SWW1617GN_0301_T5508 SW Version : amigo4.0 Action completed Time taken : 00:00:11 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM9 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 0551 CPU_SW: 0001 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Getting connection agent statusreloader Send boot2 ... Receive SYNC signal, Boot2 runs normally. Getting RAM info ... SRAM: type[0x2] base_address[0x200000] size[0x50000] DRAM: type[0x1] base_address[0x40000000] size[0x80000000] Getting H/W info ... CHIP : MT6757 CPU ID : EMMC ID : 150100444836444D420536B6C8504401 EMMC Size: 64GB, usable capacity: 58.25GB EMMC Name: eMMC_Samsung_DH6DMB Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:10 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 Created: 12/26/2017 6:14:05 PM |
12-27-2017, 14:51 | #5300 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile I8i SPD7731C Read Info / Read Factory Firmware Done By CS-Tool QMobile I8i SPD7731C Read Info / Read Factory Firmware Done By CS-Tool Read Info Read File Br FactoryFilePak CS-Tool Team |
The Following 4 Users Say Thank You to FactoryFilePak For This Useful Post: |
12-27-2017, 14:55 | #5301 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile M88 SPD7731G Read Info /Read File / Format/Reset Done By CS-Tool QMobile M88 SPD7731G Read Info /Read File / Format/Reset Done By CS-Tool Read Info Read File Format/Reset Br FactoryFilePak CS-Tool Team |
The Following 6 Users Say Thank You to FactoryFilePak For This Useful Post: |
12-27-2017, 15:43 | #5302 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Nokia 230 SPD6531 Read File / Format/Reset Done By CS-Tool Nokia 230 SPD6531 Read File / Format/Reset Done By CS-Tool Read File Format/Reset Br FactoryFilePak CS-Tool Team |
12-27-2017, 15:46 | #5303 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Qmobile I5 MT6582 Unfornatuley Error Remove Done By Flashing With CS-Tool Qmobile I5 MT6582 Unfornatuley Error Remove Done By Flashing With CS-Tool Br FactoryFilePak CS-Tool Team |
12-27-2017, 15:54 | #5304 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Infinix X556 Hot 4 Pro MTK6735M Read Factory File Done By CS-Tool Infinix X556 Hot 4 Pro MTK6735M Read Factory File Done By CS-Tool Br FactoryFilePak CS-Tool Team |
12-27-2017, 15:56 | #5305 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Infinix X556 Hot 4 Pro MTK6735M FRP Reset Done By CS-Tool Infinix X556 Hot 4 Pro MTK6735M FRP Reset Done By CS-Tool Br FactoryFilePak CS-Tool Team |
12-27-2017, 16:00 | #5306 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Rivo C130 MTK6261 Read File/Read Code Done By CS-Tool Rivo C130 MTK6261 Read File/Read Code Done By CS-Tool Read File Read Code Br FactoryFilePak CS-Tool Team |
The Following 5 Users Say Thank You to FactoryFilePak For This Useful Post: |
12-29-2017, 12:40 | #5307 (permalink) |
Freak Poster Join Date: May 2014
Member: 2188520 Status: Offline Sonork: 100.1655753 Thanks Meter: 44 | qmobile noir E1 FRP DONE BY KING CS TOOL :) qmobile noir E1 MT6737M FRP DONE BY KING CS TOOL Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM16 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 0335 CPU_SW: 0000 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100523331424142 CHIP : MT6737M CPU ID : EMMC ID : 150100523331424142 EMMC Size: 16GB, usable capacity: 14.57GB EMMC Name: eMMC_Samsung_R31BAB Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:28 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 |
The Following User Says Thank You to rizwan yaqoob For This Useful Post: |
12-30-2017, 11:58 | #5308 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | lenovo A606 MT6582 Read Pattern Done By CS-Tool lenovo A606 MT6582 Read Pattern Done By CS-Tool Br FactoryFilePak CS-Tool Team |
12-30-2017, 12:01 | #5309 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile I5 MT6582 Format/Reset Done By CS-Tool QMobile I5 MT6582 Format/Reset Done By CS-Tool Br FactoryFilePak CS-Tool Team |
12-30-2017, 12:04 | #5310 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile I5 MT6582 Hang On Logo Done By CS-Tool QMobile I5 MT6582 Hang On Logo Done By CS-Tool Br FactoryFilePak CS-Tool Team Last edited by FactoryFilePak; 12-30-2017 at 12:59. |
