01-01-2018, 11:28 | #5311 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | MICROMAX A62 pattern lock reset done..!! Boot : SC6820-NAND Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM12) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 921600 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 8810 SC Boot Mode : 8810000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 88100001 CPU ID : 88100001 NAND ID : 00AD00BCFFFFFFFF NAND Size: 512MB NAND Name: NAND_H8BCS0UN0MCR Boot Information completed. Reading Locks Location.. Reseting Locks..... Reset done [ insert simcard & enter any keys ] Action completed Time taken : 00:04:09 Reconnect Battery/USB Cable CS-Tool Ver 1.56 |
The Following User Says Thank You to jjamshad5 For This Useful Post: |
01-02-2018, 07:09 | #5312 (permalink) |
Product Supporter Join Date: Jul 2015 Location: pk
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile Evok Power MT6580 FRP Reset Done By CS-Tool QMobile Evok Power MT6580 FRP Reset Done By CS-Tool Br FactoryFilePak CS-Tool Team |
The Following 2 Users Say Thank You to FactoryFilePak For This Useful Post: |
01-02-2018, 07:20 | #5313 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile I6i MT6580 Logo Stuck Fix Done Only Flashing With CS-Tool QMobile I6i MT6580 Logo Stuck Fix Done Only Flashing With CS-Tool Br FactoryFilePak CS-Tool Team |
The Following User Says Thank You to FactoryFilePak For This Useful Post: |
01-02-2018, 07:28 | #5314 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | invens Royal R5 SPD7731C Read Info / Read Factory File / Format/Reset Done By CS-Tool qinvens Royal R5 SPD7731C Read Info / Read Factory File / Format/Reset Done By CS-Tool Read Info Read Factory File Format/Reset Br FactoryFilePak CS-Tool Team |
01-02-2018, 07:33 | #5315 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile E600 Music MT6261 Read Code Done By CS-Tool QMobile E600 Music MT6261 Read Code Done By CS-Tool Br FactoryFilePak CS-Tool Team |
01-03-2018, 14:48 | #5316 (permalink) |
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | Xplay y160 user code reset done Action : Reset Codes Boot : SC6820-NAND Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM44) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 921600 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 8810 SC Boot Mode : 8810004000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC8810 CPU ID : 88100040 NAND ID : 002C00BCFFFFFFFF NAND Size: 512MB NAND Name: NAND_MT29F4G08ABC_2 Boot Information completed. Reading Locks Location.. Reseting Locks..... Reset done [ insert simcard & enter any keys ] Action completed Time taken : 00:04:01 Reconnect Battery/USB Cable CS-Tool Ver 1.56 |
01-04-2018, 19:24 | #5317 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | oppo f1s read pattern done with cstool S-Module select meizu tab Action : Read Pattern Lock In FlashMode Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM27 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0001 CPU_HW: CB00 CPU_ID: 0326[MT6755] SecConf: 00000001 Decryping(Meizu)... Error: mn1 uploading boot image to RAM... Handshake received from Phone. Getting connection agent status:brom Init DRAM... Waiting for DRAM detection... Selected: 1/0 ...OK Send boot2 ... Receive SYNC signal, Boot2 runs normally. Getting RAM info ... SRAM: type[0x2] base_address[0x200000] size[0x40000] DRAM: type[0x1] base_address[0x40000000] size[0x80000000] Getting H/W info ... CHIP : MT6755/6750 CPU ID : EMMC ID : 150100525831424D42074278D4A793DD EMMC Size: 32GB, usable capacity: 29.13GB EMMC Name: eMMC_Samsung_RX1BMB Reading Pattern code ... Data found. checking ... 1 2 3 4 5 6 7 8 9 Code= 35789 Lock create date: 11/4/2017 7:43:53 PM Action completed Time taken : 00:00:33 |
01-06-2018, 08:18 | #5318 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Peace PR360 Privacy lock Done Action : Reset Privacy Lock Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM156 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Removing privacy lock ... Done. Action completed Time taken : 00:00:10 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 |
The Following User Says Thank You to sajid01913 For This Useful Post: |
01-06-2018, 09:46 | #5319 (permalink) |
01-07-2018, 14:50 | #5320 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | winmax wx20 passcode reset done Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM457 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6261 CPU_SW: CB01 CPU_HW: 8000 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6261 CPU ID : 00000000 NOR ID : 00C2002000160000 NOR Size : 4MB NOR Name : [MXIC] MX25L3291FWJI_09 NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. Reading Phone Info... Project ID: MAUI.11C.W13.52.MP.V2.F9 Formatting ... Format done. Action completed Time taken : 00:00:24 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 |
01-07-2018, 15:54 | #5321 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Alcatel ot4013d flashing done ALCATEL OT4013D FLASHING DONE BY CS-TOOL Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100463558354342 CHIP : MT65720000 CPU ID : EMMC ID : 150100463558354342 EMMC Size: 4GB, usable capacity: 3,65GB EMMC Name: eMMC_Samsung_F5X5CB Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. New EMI config is detected, auto added it to User Database, cnt=4 Saved to: C:\CS-Tool\CST_MainSoftware\private\db\emi\ Image Format: General Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading ebr2 ......ok Downloading custpack ......ok Downloading mobile_info ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:07:23 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 |
The Following User Says Thank You to fokal2008 For This Useful Post: |
01-09-2018, 09:07 | #5322 (permalink) |
Freak Poster Join Date: Mar 2012 Location: somewhere in world Age: 37
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | Infinix NOte 4 Naught version Frp remove done in few sec. |
The Following User Says Thank You to sonualok For This Useful Post: |
01-13-2018, 14:01 | #5323 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Symphony i10 FRP Done Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM156 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100463832324D42 CHIP : MT65800000 CPU ID : EMMC ID : 150100463832324D42 EMMC Size: 16GB, usable capacity: 14.57GB EMMC Name: eMMC_Samsung_F822MB Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:16 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 |
01-13-2018, 15:31 | #5324 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Repair IMEI Done Action : Android Repair IMEI(DownloadBoot Mode) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM156 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 1501004E4A5330304D CHIP : MT65800000 CPU ID : EMMC ID : 1501004E4A5330304D EMMC Size: 4GB, usable capacity: 3.64GB EMMC Name: eMMC_Samsung_KMNJS000ZM_B205 Read Hardware Information is done. Checking imei ... NVDAT FOUND. new imei1: 35214********** new imei2: 35218********** Repairing Imei... Verify Required... Updating NVDATA... Checking CRC: NVRAM ...ok all done ... Action completed Time taken : 00:00:13 Reconnect Battery/USB Cable CS-Tool Ver 1.58.2 |
01-14-2018, 13:07 | #5325 (permalink) |
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | GFive SPD6531 Format/Reset Done By CS-Tool GFive SPD6531 Format/Reset Done By CS-Tool Br FactoryFilePak CS-Tool Team |
