01-31-2018, 03:35 | #5356 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Quote:
01-31-2018, 10:06 | #5358 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | TECNO W3 FRP RESET DONE Code: Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM50 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 6580 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100464E58324D42 CHIP : MT65800000 CPU ID : EMMC ID : 150100464E58324D42 EMMC Size: 8GB, usable capacity: 7,29GB EMMC Name: eMMC_Samsung_FNX2MB Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:19 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
01-31-2018, 10:14 | #5359 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | KAGOO S8 MINI SPD SC8810 TOO MANY PATTERN LOCK RESET DONECode: Action : Reset Too many pattern lock Boot : SC8810-NAND Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SCI USB2Serial (COM29) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 115200 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 8810 SC Boot Mode : 8810004000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC8810 CPU ID : 88100040 NAND ID : 00EC00BCFFFFFFFF NAND Size: 512MB NAND Name: NAND_K9K4G16Q0M Boot Information completed. Reading Locks Location.. |
01-31-2018, 10:19 | #5360 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | [QUOTE=fokal2008;12937675] KAGOO S8 MINI SPD SC8810 TOO MANY PATTERN LOCK RESET DONECode: Action : Reset Too many pattern lock Boot : SC8810-NAND Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SCI USB2Serial (COM29) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 115200 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 8810 SC Boot Mode : 8810004000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC8810 CPU ID : 88100040 NAND ID : 00EC00BCFFFFFFFF NAND Size: 512MB NAND Name: NAND_K9K4G16Q0M Boot Information completed. Reading Locks Location.. |
01-31-2018, 10:48 | #5361 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Symphony i10 FRP Done Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM156 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 6580 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100463832324D42 CHIP : MT65800000 CPU ID : EMMC ID : 150100463832324D42 EMMC Size: 16GB, usable capacity: 14.57GB EMMC Name: eMMC_Samsung_F822MB Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:23 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
01-31-2018, 14:52 | #5362 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | No Call Log Solve by Format/Reset Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM457 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CB01 CPU_HW: 8000 CPU_ID: 6261 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6261 CPU ID : 00000000 NOR ID : 00C8006000160000 NOR Size : 4MB NOR Name : [GigaDevice] GD25LQ32 NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. Reading Phone Info... Project ID: MAUI.11C.W13.52.MP.V2.F10 Formatting ... Format done. Action completed Time taken : 00:00:20 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
01-31-2018, 14:52 | #5363 (permalink) |
The Following User Says Thank You to sajid01913 For This Useful Post: |
02-01-2018, 15:02 | #5364 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | samsung b310e reset passcode Action : Format / Reset Boot : SC6530-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM253) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6530 SC Boot Mode : 6530C00000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC6500E CPU ID : 6530C000 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 Boot Information completed. Reading FileSystem info... FileSystem Version: 7C Start=0x00690000, Size=0x00170000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:52 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
02-01-2018, 15:03 | #5365 (permalink) |
02-06-2018, 12:12 | #5366 (permalink) | |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | qnet pattern lock solved Quote:
02-06-2018, 12:12 | #5367 (permalink) | |
The Following User Says Thank You to ernie78™ For This Useful Post: |
02-08-2018, 12:18 | #5368 (permalink) |
Product Supporter Join Date: Jul 2015 Location: pk
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | QMobile E60 MT625A Read Code Done By CS-Tool Code: Action : Read Codes Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM3 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CA01 CPU_HW: 8000 CPU_ID: 625A Switching to Meta Mode... Waiting for mete ack... handshake protocol is done. Reading ... password: 51214 password: 0017 password: 52211 Action completed Time taken : 00:00:38 Reconnect Battery/USB Cable CS-Tool Ver 1.59 Br FactoryFilePak CS-Tool Team |
