08-06-2018, 09:32 | #5581 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM14) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00EF006000170000 NOR Size : 8MB NOR Name : SF_W25Q64DW Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x00778000, Size=0x00088000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:19 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
The Following User Says Thank You to sajid01913 For This Useful Post: |
08-08-2018, 07:56 | #5582 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Samsung B310E Pin/Password Reset Done Action : Format / Reset Boot : SC6530-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM223) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6530 SC Boot Mode : 6530C00000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC6500E CPU ID : 6530C000 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 Boot Information completed. Reading FileSystem info... FileSystem Version: 7C Start=0x00690000, Size=0x00170000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:56 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
08-09-2018, 16:44 | #5583 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Symphony V130 FRP Reset Done Action : Reset all settings / FRP Boot : SC7731C-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM223) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Read info is done. Reading Project Property ... done. Android7.0 resetting all settings ... All done. Action completed Time taken : 00:00:28 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
08-12-2018, 13:45 | #5584 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | itel5040 Reset Done Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM464 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CB01 CPU_HW: 8000 CPU_ID: 6261 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6261 CPU ID : 00000000 NOR ID : 00EF007000160000 NOR Size : 4MB NOR Name : [Winbond] SF_W25Q32JV NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. Reading Phone Info... Project ID: it5040-DL183-EnBn-BD-20171115-SupN Formatting ... Format done. Action completed Time taken : 00:00:19 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
08-14-2018, 16:22 | #5585 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Walton Olvio S31 Pin/Password Reset Done Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM464 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CB00 CPU_HW: 8000 CPU_ID: 6260 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6260 CPU ID : 00000000 NOR ID : 00EF004000160000 NOR Size : 4MB NOR Name : [WINBOND] W25Q32BV NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. Formatting ... Format done. Action completed Time taken : 00:00:27 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
08-21-2018, 16:31 | #5586 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Symphony D101 Dead boot repair done only by CS-Tool Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM635 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CB00 CPU_HW: 8000 CPU_ID: 6260 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6260 CPU ID : 00000000 NOR ID : 00EF006000180000 NOR Size : 16MB NOR Name : [WINBOND] W25Q128FW NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. checking uid protection... not found, it is safe. Programming Flash Image... Erasing.. Erasing done, Programming ... Load File : C:\Users\Amit\Desktop\Symphony_W128_V01.0_1_03\RDR 60A_F162_PCB01_GPRS_MT6260_S00.D101_HW2_V10.BIN Programming Flash Image Completed. Action completed Time taken : 00:02:58 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
12-21-2018, 15:19 | #5587 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Symphony w71i Pin Remove Success Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM157 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA01 CPU_ID: 6572 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034473930 CHIP : MT65720000 CPU ID : EMMC ID : 110100303034473930 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_TYD0FH221618RA Read Hardware Information is done. Formatting ... Format done Action completed Time taken : 00:00:23 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
The Following 2 Users Say Thank You to sajid01913 For This Useful Post: |
01-05-2019, 14:27 | #5588 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Tinmo F600 no call log Reset Done Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM253) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00EF004000160000 NOR Size : 4MB NOR Name : SF_W25Q32BV Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x003D8000, Size=0x00028000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:14 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
01-13-2019, 15:40 | #5589 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | Frp huawei cnu-u29 Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0001 CPU_HW: CA01 CPU_ID: 6582 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Tips 1: In case some phone required to hold bootkey to enter download boot mode Tips 2: SecureBoot phone found, According to the brand, Select the supported signed DA from boots list and try again. Action completed Time taken : 00:00:18 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
The Following User Says Thank You to mahi20015 For This Useful Post: |
01-17-2019, 14:01 | #5590 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | itel it5320 Hang logo Solved by Format Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM7) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x00778000, Size=0x00088000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:17 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
01-17-2019, 14:01 | #5591 (permalink) |
01-17-2019, 15:44 | #5592 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Lenovo A2010-a FRP Remove Success Brand : Lenovo Phone Model : Lenovo A2010-a Android Ver : 5.1 CPU/Processor : MT6735M MTK Project ver: A2010-a-t_USR_S264_1701101300_MP3V1_8G_ROW SW Version : A2010-a-t_S264_1701101300_MP3V1_8G_ROW Userdata State : Normal ****************************** Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0335[MT6735M_S01] BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100463732324D42 CHIP : MT6735M/8735M CPU ID : EMMC ID : 150100463732324D42 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Samsung_F722MB Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:19 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
01-20-2019, 08:18 | #5593 (permalink) |
Product Supporter Join Date: Jul 2015 Location: pk
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Huawei Ascend Y511-U30 MTK6572 Read Pattern Done By CS-Tool Code: Action : Read Pattern Lock In FlashMode Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM72 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA01 CPU_ID: 6572 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Reading Pattern code ... Data found. checking ... 1 2 3 4 5 6 7 8 9 Code= 4583 Lock create date: 1/19/2019 2:54:14 PM Action completed Time taken : 00:00:14 Reconnect Battery/USB Cable CS-Tool Ver 1.60 Br FactoryFilePak CS-Tool Team |
The Following User Says Thank You to FactoryFilePak For This Useful Post: |
01-20-2019, 16:45 | #5594 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | WALTON Primo GH6+ FRP Reset Done Brand : WALTON Phone Model : Primo GH6+ Android Ver : 6.0 CPU/Processor : MT6580 MTK Project ver: ALPS.W10.24.p0 SW Version : MRA58K release-keys Userdata State : Normal ********************************** Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 6580 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A484147326505 CHIP : MT65800000 CPU ID : EMMC ID : 90014A484147326505 EMMC Size: 16GB, usable capacity: 14.69GB EMMC Name: eMMC_Hynix_HAG2e Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:22 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
01-20-2019, 16:45 | #5595 (permalink) |
