08-28-2015, 07:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: AVJ (KOLKATA)
Member: 759058 Status: Offline Sonork: 1597286 Thanks Meter: 58 | lava iries 370 patern reset failed Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found [ USB Port:COM24 ] Driver: \Device\SciU2S0 Connecting... Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Action completed Time taken : 00:00:49 Reconnect Battery/USB Cable CS-Tool Ver 1.31 but done by infinity Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
08-28-2015, 07:11 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Waiting for Phone Usb.... Phone found [ USB Port:COM24 ] Driver: \Device\SciU2S0 Connecting... Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... something mistake from u r side |
08-28-2015, 07:35 | #5 (permalink) |
Member: 759058 Status: Offline Sonork: 1597286 Thanks Meter: 58 | only not 7715, 7731 also not supported intex aqua y2+ read patern by infinity success Operation : Read PatternLock [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 7412365 Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
08-28-2015, 08:16 | #8 (permalink) | |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | Quote:
And CS-Tool Team know all about that. YES. You can use other tool for working. Why you post about other tool in cs-tool section.? | |
08-28-2015, 08:17 | #9 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Mr. JD . . If You are Really A Hard Working Programmer, You should never worry about others what they are doing or what they are not..! Your again n again coming here reflects that you are afraid of cs-tool and keeping an eye on it always...thats bad enough for a professional like you. You are what YOU ARE. Everyone knows your reputation, dont let it be down by posting these types of jealousy craps here. Next time dont post here instead post in your section. bR. |
The Following 2 Users Say Thank You to Moiz Khan For This Useful Post: |
