10-14-2017, 14:12 | #1 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2729103 Status: Offline Thanks Meter: 0 | Meizu fix IMEI error Operation: Android fix IMEI (download mode) Meizu Model: Common (MTK) Prompt: Method 1. remove the battery, insert the USB line, and then install the battery Method 2. mobile phone shutdown, reinstall the battery, and then insert the USB line... Some mobile phones may need to hold down a boot key Searching for USB port automatically... USB device insertion, USB port =COM24 has been detected Trying to connect online... Online completion Reading CPU information... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 6795 SecConf: 00000007 Decrypting (Meizu)... Error: Mn4 Error: setting parameter failed All operations are finished Time consuming: 00:06:06 If you need to reconnect, reinstall the battery /USB line CS-Tool Ver 1.33 |
