02-20-2018, 08:44 | #1 (permalink) |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | meizu m3 note m681c Format/Reset Done By CS-Tool Format/Reset Done By CS-Tool Code: Action : Reset FileSystem Brand: Meizu Model: E2 Tips: 1.Remove Battery, Insert usb cable, Insert battery [Preloader Mode] 2.power off Phone, Remove & Reinsert Battery , insert USB Cable [Preloader Mode] (In Case Some Phone Required to hold bootkey) [BROM Mode] Some phones need to connect in Brom Mode, and some in Preloader model Waiting for Phone Usb (Press "F2" to activate fast scan mode)... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MTK USB Port (COM340) Phone found [ USB Port:COM340 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0001 CPU_HW: CB00 CPU_ID: 0326[MT6755] BV: FE SecConf: 00000007 Decryping(Meizu)...ok uploading boot image to RAM... Handshake received from Phone. Getting connection agent status:brom Init DRAM... Waiting for DRAM detection... Selected: 1/3 ...OK Send boot2 ... Receive SYNC signal, Boot2 runs normally. Getting RAM info ... SRAM: type[0x2] base_address[0x200000] size[0x40000] DRAM: type[0x1] base_address[0x40000000] size[0x80000000] Getting H/W info ... CHIP : MT6755/6750 CPU ID : EMMC ID : 150100513832334D42005608C4C973FB EMMC Size: 16GB, usable capacity: 14,57GB EMMC Name: eMMC_Samsung_Q823MB Unlocking ... Data found. checking ... Unlock Done. Action completed Time taken : 00:00:41 Reconnect Battery/USB Cable CS-Tool Ver 1.38.1 |
The Following User Says Thank You to Xaker2012 For This Useful Post: |
02-20-2018, 09:35 | #2 (permalink) | |
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Action : Format / Reset Quote:
02-20-2018, 09:36 | #3 (permalink) | |
02-20-2018, 10:03 | #4 (permalink) |
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Action : Read Info [CODE] Action : Read Info Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery [Preloader Mode] 2.power off Phone, Remove & Reinsert Battery , insert USB Cable [Preloader Mode] (In Case Some Phone Required to hold bootkey) [BROM Mode] Some phones need to connect in Brom Mode, and some in Preloader model Waiting for Phone Usb (Press "F2" to activate fast scan mode)... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MTK USB Port (COM344) Phone found [ USB Port:COM344 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0001 CPU_HW: CB00 CPU_ID: 0326[MT6755] BV: FE SecConf: 00000007 Decryping(Meizu)...ok uploading boot image to RAM... Handshake received from Phone. Getting connection agent status:brom Init DRAM... Waiting for DRAM detection... Selected: 1/3 ...OK Send boot2 ... Receive SYNC signal, Boot2 runs normally. Getting RAM info ... SRAM: type[0x2] base_address[0x200000] size[0x40000] DRAM: type[0x1] base_address[0x40000000] size[0x80000000] Getting H/W info ... CHIP : MT6755/6750 CPU ID : EMMC ID : 150100513832334D42005608C4C973FB EMMC Size: 16GB, usable capacity: 14,57GB EMMC Name: eMMC_Samsung_Q823MB Boot Information completed. Reading Project Property ... Brand : Meizu Phone Model : M681C Android Ver : 5.1 CPU/Processor : MT6755 MTK Project ver: ALPS.L1.MP10.PRE.V1_WT6755.66.SZ.L_P90 SW Version : Flyme 5.11.3.4A Userdata State : Normal Action completed Time taken : 00:00:37 Reconnect Battery/USB Cable CS-Tool Ver 1.38.1 /CODE] |
02-20-2018, 10:29 | #5 (permalink) |
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Action : Read Flash Code: Action : Read Flash Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery [Preloader Mode] 2.power off Phone, Remove & Reinsert Battery , insert USB Cable [Preloader Mode] (In Case Some Phone Required to hold bootkey) [BROM Mode] Some phones need to connect in Brom Mode, and some in Preloader model Waiting for Phone Usb (Press "F2" to activate fast scan mode)... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MTK USB Port (COM344) Phone found [ USB Port:COM344 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0001 CPU_HW: CB00 CPU_ID: 0326[MT6755] BV: FE SecConf: 00000007 Decryping(Meizu)...ok uploading boot image to RAM... Handshake received from Phone. Getting connection agent status:brom Init DRAM... Waiting for DRAM detection... Selected: 1/3 ...OK Send boot2 ... Receive SYNC signal, Boot2 runs normally. Getting RAM info ... SRAM: type[0x2] base_address[0x200000] size[0x40000] DRAM: type[0x1] base_address[0x40000000] size[0x80000000] Getting H/W info ... CHIP : MT6755/6750 CPU ID : EMMC ID : 150100513832334D42005608C4C973FB EMMC Size: 16GB, usable capacity: 14,57GB EMMC Name: eMMC_Samsung_Q823MB USB STATUS: full-speed usb switching to high speed ... New Port: COM2 ......ok Dumping Flash Image Now... Dumping Flash Image Completed. Flash Image size : 14918,00MB Saved to: C:\Users\Roman\Desktop\meizu m3 note m681c\meizu m681c.cst Action completed Time taken : 00:17:38 Reconnect Battery/USB Cable CS-Tool Ver 1.38.1 |
