02-07-2016, 11:42 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: In Think
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | Micromax A066 imei repair problem Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM8 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6571 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034473930 CHIP : MT65710000 CPU ID : EMMC ID : 110100303034473930 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_TYD0FH221618RA Read Hardware Information is done. Checking imei ... old IMEI1: 911378001****** old IMEI2: 911378001****** new imei1: 911378001****** new imei2: 911378001****** Repairing Imei... Verify Required... Warning!!! Disconnect USB Cable From Phone. Reconnect Again USB Cable. Waiting for Phone Usb... scanning the mtk usb device...... Phone found Connecting... Posting ... Imei Check.. All Done. still invalid imei how to repair imei br kasam |
02-07-2016, 13:28 | #2 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Bro goto settings and check if baseband is ok or not.. If baseband is unknown then you must first correct baseband first before imei must work ok.... Without correcting baseband imei writing is useless ok., |
02-07-2016, 14:23 | #5 (permalink) |
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM8 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6571 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034473930 CHIP : MT65710000 CPU ID : EMMC ID : 110100303034473930 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_TYD0FH221618RA Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Erasing all partitions ......ok Downloading preloader ......ok Updating rom info ......ok Updating partition table mirror ... Rebuild done. Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok Updating partition table mirror ... Rebuild done. All done. Action completed Time taken : 00:02:29 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 Created: 2/6/2016 5:56:41 PM sir alredy flashed |
02-07-2016, 15:18 | #6 (permalink) |
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | full format with sptool then reflash with format all + download imei repair with cstool done my problem solved |
The Following User Says Thank You to Pragyan_Gehlot For This Useful Post: |
