need to test point for BQ Aquaris X. |
Good update Need oppo & Xiaomi Latest model support |
Pleasa Sir add xiaomi auth flashing |
pls fix mi max3 after reset mi account no wifi issue |
vivo vivo Y21L unlock done without data lose Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM148) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.3 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo Y21L [msm8916] Software : LMY47V release-keys, eng.compiler.20180317 [Sat Mar 17 18:54:47 CST 2018] Android Ver. : 5.1.1 Patch Level : 2018-03-01 USERDATA : Normal For Normal userdata, you can use [Reset Locks] button. Reading Extended Information...OK Model : vivo Y21L Resetting Locks (Vivo)...Done Please wait for phone to reboot. Operation Finished. QcFire Ver. 4.0 |
thanks for update umt team |
Redmi Note 4X flashing failed. Still same problem as before. Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM119) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [adspso.bin] -> [dsp] ...Done Writing [fs_image.tar.gz.mbn.img] -> [fsg] ...Done Writing [sec.dat] -> [sec] ...Done Writing [splash.img] -> [splash] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [system.img ] -> [system]...FailedFailed Operation Finished. QcFire Ver. 4.0 |
hello umt team i was flashing vio y51L suddenly flashing stoped at system partiton but after i flash this phone with qfil report success why umt failed system partition most of the handset please fix this bug i have returned many handset because of hardware problem but it was not hardware problem it was umt bug problem which cause system fail only system partition please fix asap by the way thanks for update |
pocophone f1 Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [SD845] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [SD845]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.0 |
Good update Pls Add oppo A3s Thank's |
vivo v15 pro err Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM318) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500900 [E1500900] 03007300 OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A53 9670EA259771BA Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Finished. QcFire Ver. 4.0 Sabah Mangattupulam |
Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1724 Software : OPM1.171019.011 release-keys, eng.compil.20180926.200120 [Wed Sep 26 20:01:20 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-09-01 USERDATA : Encrypted Reading Extended Information...OK Model : vivo 1801 Product : PD1731BF_EX Cust. Name : PD1731BF_EX_IN_NULL_NULL Version : PD1731BF_EX_A_1.10.2 Resetting Locks (Vivo)...Done Please wait for phone to reboot. Operation Finished. QcFire Ver. 4.0 |
LENOVO Lenovo YT3-850M [msm8909] frp done thank you UMT Team Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LENOVO Lenovo YT3-850M [msm8909] Software : YT3-850M_S000114_161125_ROW, YT3-850M_S000114_161125_ROW [Fri Nov 25 07:02:09 CST 2016] Android Ver. : 6.0.1 Patch Level : 2016-11-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 4.0 ..............................................Than k you UMT Team......................................... |
