Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 04-02-2019, 17:00   #46 (permalink)
79mobile's Avatar
Member: 272091
Sonork: 100:114011
Thanks Meter: 129
need to test point for BQ Aquaris X.
Old 04-03-2019, 03:56   #47 (permalink)
Member: 2111816
Good update
Need oppo & Xiaomi Latest model support
Old 04-03-2019, 04:12   #48 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 544
Originally Posted by rameshwarpooja View Post
C:\UMTool\QcFire\QCN_Backup\8953.gen_----_000000000000000_190402_081150.qcn
i already write QCN But Same
Old 04-03-2019, 05:06   #49 (permalink)
Member: 1622614
Thanks Meter: 56
Pleasa Sir add xiaomi auth flashing
Old 04-03-2019, 05:14   #50 (permalink)
Member: 219732
Thanks Meter: 9
pls fix mi max3 after reset mi account no wifi issue
Old 04-03-2019, 06:04   #51 (permalink)
Wasim007's Avatar
Member: 500302
Thanks Meter: 142
Arrow vivo vivo Y21L unlock done without data lose
Operation : Reset Locks (Vivo)
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM148)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.3
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1507000 [8916] 00000000
OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8916_014]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : 8916, eMMC, 16 GB
LU Count : 1 [0x01D1F000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : vivo vivo Y21L [msm8916]
Software : LMY47V release-keys, eng.compiler.20180317 [Sat Mar 17 18:54:47 CST 2018]
Android Ver. : 5.1.1
Patch Level : 2018-03-01
USERDATA : Normal
For Normal userdata, you can use [Reset Locks] button.
Reading Extended Information...OK
Model : vivo Y21L
Resetting Locks (Vivo)...Done
Please wait for phone to reboot.
Operation Finished.
QcFire Ver. 4.0
The Following 2 Users Say Thank You to Wasim007 For This Useful Post:
Old 04-03-2019, 07:33   #52 (permalink)
Member: 2637597
Sonork: 100.1680047
Thanks Meter: 9
thanks for update umt team
Old 04-03-2019, 07:56   #53 (permalink)
Member: 1109337
Thanks Meter: 166
Originally Posted by U.M.T View Post
Please send us link to this firmware to download and check.
Br,
UMT
Micromax_E4816_SW_V1.8_HW_V1.0.0_02052017_QFIL
Old 04-03-2019, 12:43   #54 (permalink)
Member: 2516133
Thanks Meter: 52
Redmi Note 4X flashing failed. Still same problem as before.
Operation : Flash
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM119)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Hardware ID : E1600400 [8953] 00000000
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Sending Loader [8953]...Done
Hardware : 8953, eMMC, 32 GB
LU Count : 1 [0x03A3E000]
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Writing [NON-HLOS.bin] -> [modem] ...Done
Writing [sbl1.mbn] -> [sbl1] ...Done
Writing [sbl1.mbn] -> [sbl1bak] ...Done
Writing [rpm.mbn] -> [rpm] ...Done
Writing [rpm.mbn] -> [rpmbak] ...Done
Writing [tz.mbn] -> [tz] ...Done
Writing [tz.mbn] -> [tzbak] ...Done
Writing [devcfg.mbn] -> [devcfg] ...Done
Writing [devcfg.mbn] -> [devcfgbak] ...Done
Writing [adspso.bin] -> [dsp] ...Done
Writing [fs_image.tar.gz.mbn.img] -> [fsg] ...Done
Writing [sec.dat] -> [sec] ...Done
Writing [splash.img] -> [splash] ...Done
Writing [emmc_appsboot.mbn] -> [aboot] ...Done
Writing [emmc_appsboot.mbn] -> [abootbak] ...Done
Writing [boot.img] -> [boot] ...Done
Writing [recovery.img] -> [recovery] ...Done
Writing [system.img ] -> [system]...FailedFailed
Operation Finished.
QcFire Ver. 4.0
Old 04-03-2019, 13:55   #55 (permalink)
Member: 2663223
Thanks Meter: 2
hello umt team i was flashing vio y51L suddenly flashing stoped at system partiton but after i flash this phone with qfil report success why umt failed system partition most of the handset please fix this bug i have returned many handset because of hardware problem but it was not hardware problem it was umt bug problem which cause system fail only system partition please fix asap by the way thanks for update
Old 04-03-2019, 15:28   #56 (permalink)
Member: 2068216
Sonork: redfoxvpn
Thanks Meter: 7
pocophone f1
Operation : Disable Mi Account
Found Port : Qualcomm HS-USB QDLoader 9008 (COM11)
Hardware ID : E1B00800 [SD845] 00007200
OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4
Using Auto Loader Selection [4]
No compatible loader found. Device may not boot with this loader.
Sending Loader [SD845]...Write Error!
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 4.0
Old 04-04-2019, 07:49   #57 (permalink)
gsmcare1's Avatar
Member: 728839
Thanks Meter: 26
Good update Pls Add oppo A3s
Thank's
Old 04-04-2019, 08:05   #58 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 274
vivo v15 pro err
Found Port : Qualcomm HS-USB QDLoader 9008 (COM318)
Hardware ID : E1500900 [E1500900] 03007300
OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A53 9670EA259771BA
Using Auto Loader Selection [0]
CPU not found in database.
Operation Finished.
QcFire Ver. 4.0
Sabah Mangattupulam
Old 04-04-2019, 12:21   #59 (permalink)
Member: 417084
Thanks Meter: 23
Found Port : Qualcomm HS-USB QDLoader 9008 (COM9)
Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2
Hardware ID : E1600500 [8917] 00000000
OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2
Sending Loader [8917_001]...Done
Hardware : 8917, eMMC, 16 GB
LU Count : 1 [0x01D5A000]
Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512
Device : vivo vivo 1724
Software : OPM1.171019.011 release-keys, eng.compil.20180926.200120 [Wed Sep 26 20:01:20 CST 2018]
Android Ver. : 8.1.0
Patch Level : 2018-09-01
USERDATA : Encrypted
Model : vivo 1801
Product : PD1731BF_EX
Cust. Name : PD1731BF_EX_IN_NULL_NULL
Version : PD1731BF_EX_A_1.10.2
Operation Finished.
QcFire Ver. 4.0
The Following User Says Thank You to vinaykmobile For This Useful Post:
Old 04-05-2019, 05:46   #60 (permalink)
Member: 2306060
Thanks Meter: 8
LENOVO Lenovo YT3-850M [msm8909] frp done thank you UMT Team
Operation : Format FS
Port : Qualcomm HS-USB QDLoader 9008 (COM10)
Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6
Opening Port...OK
Hardware ID : E1009600 [8909] 00000000
Using Auto Loader Selection [2]
Sending Loader [8909_012]...Done
Hardware : 8909, eMMC, 16 GB
Device : LENOVO Lenovo YT3-850M [msm8909]
Software : YT3-850M_S000114_161125_ROW, YT3-850M_S000114_161125_ROW [Fri Nov 25 07:02:09 CST 2016]
Android Ver. : 6.0.1
Patch Level : 2016-11-01
Preparing Data...Done
Formatting Userdata...Done
Resetting FRP Lock.......Done
Operation Finished.
QcFire Ver. 4.0
..............................................Than k you UMT Team.........................................
The Following User Says Thank You to [email protected] For This Useful Post:
Page generated in 0.42609 seconds with 7 queries
