01-04-2020, 10:42 | #31 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM94) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [SDM845] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Preparing Loader...Done Sending Loader [PocoF1_beryllium]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.2 |
01-04-2020, 10:55 | #32 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
Simpaly Uncheck Auto Loader And Try Again | |
01-04-2020, 11:55 | #36 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
The Following User Says Thank You to Franky_36 For This Useful Post: |
01-04-2020, 12:06 | #38 (permalink) | |
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Quote:
Thanks for the replay! I read and know all of that and think that update is VERY USEFUL POCO firmware is that version: Device Id : beryllium_global Version : V10.3.8.0.PEJMIXM Code Base : 9 Ext Info : US, en, F JUST UPLOAD LOG FOR INFO to supporters as they want. THANK! | |
01-04-2020, 12:33 | #39 (permalink) |
Crazy Poster Join Date: Feb 2008
Member: 714092 Status: Offline Thanks Meter: 11 | Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM15) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.0.8.4 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ0MzA0MjQxNDE0NDVGNEMzOTQzNzY0OTYzNE YzNTQzNkUzMzY2NjUzNTQ3NkY3MzU1NTMzMzQxNTI2ODU1NDc1 MT== Getting Auth Data...Connecttion to Auth App Failed! Run Auth App if not running, or restart Auth App! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.2 |
01-04-2020, 12:33 | #40 (permalink) |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | K20 Pro Device : Xiaomi_No_Auth RedmiK20Pro_Mi9TPro_raphael Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM16) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600E00 [E1600E00] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiK20Pro_Mi9TPro_raphael]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.2 |
01-04-2020, 13:38 | #42 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Duabi
Member: 2745836 Status: Offline Sonork: @djbeka Thanks Meter: 17 | Operation : Xiaomi Boot Patch Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 5.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00B00 [8953] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Preparing Loader...Done Sending Loader [Redmi7_onclite]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.2 |
01-04-2020, 14:12 | #43 (permalink) |
Insane Poster Join Date: Jul 2016 Location: Pakistan Bannu Age: 29
Member: 2595796 Status: Offline Thanks Meter: 2 | Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiNote7_Lavender]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ0MzA0MjQxNDE0MjU5N0E1MDYyNTY1NDcyND I2QTU1NDY0RTQyNjY2QTc3Nzk1MjQ0Nzk1OTUzNUEzMzQ0NjU3 Nz== Getting Auth Data...Connecttion to Auth App Failed! Run Auth App if not running, or restart Auth App! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. |
01-04-2020, 14:30 | #44 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM24) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Preparing Loader...Done Sending Loader [Redmi6Pro_******]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.2 not working |
01-04-2020, 15:13 | #45 (permalink) |
Crazy Poster Join Date: Feb 2007 Location: earth
Member: 452306 Status: Offline Thanks Meter: 1 | Redmi Note 8 ginkgo Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [E1A01000] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiNote8_ginkgo]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.2 |
