Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 01-04-2020, 10:42   #31 (permalink)
vasko_bojilov's Avatar
Member: 877235
Sonork: vasilbojilov
Thanks Meter: 199
Device : Xiaomi_No_Auth PocoF1_beryllium
Operation : Read Information
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM94)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1B00800 [SDM845] 00007200
OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4
Initializing Protocol...OK
Preparing Loader...Done
Sending Loader [PocoF1_beryllium]...Write Error!
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 5.2
Old 01-04-2020, 10:55   #32 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
Opening Port...OK
Operation Finished.
QcFire Ver. 5.2
Simpaly Uncheck Auto Loader And Try Again
Old 01-04-2020, 11:03   #33 (permalink)
Member: 424066
Thanks Meter: 43
thanks great nice update
Old 01-04-2020, 11:34   #34 (permalink)
Member: 877235
Thanks Meter: 199
Old 01-04-2020, 11:43   #35 (permalink)
Registered User
Member: 2217155
Thanks Meter: 3
Wait for the new update released CASPER 2233 SPECIAL FOR ALL
The Following User Says Thank You to nokia300 For This Useful Post:
Old 01-04-2020, 11:55   #36 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Opening Port...OK
Operation Finished.
QcFire Ver. 5.2
Good, happy new year, before posting please read the main post or the one that puts number 1, in which it says depending on the security that has or has the xiaomi works or will give error, that does not mean that the loaders do not work or that are not tested, there are many xiaomi in the world and with very different assurances please read, thank you very much.
The Following User Says Thank You to Franky_36 For This Useful Post:
Old 01-04-2020, 11:57   #37 (permalink)
Crazy Poster
Member: 890902
Thanks Meter: 8
umt team thanks for update.................
The Following User Says Thank You to ashif0786 For This Useful Post:
Old 01-04-2020, 12:06   #38 (permalink)
Member: 877235
Thanks Meter: 199
Hello!
Thanks for the replay!
I read and know all of that and think that update is VERY USEFUL
POCO firmware is that version:
Device Id : beryllium_global
Version : V10.3.8.0.PEJMIXM
Code Base : 9
Ext Info : US, en, F
JUST UPLOAD LOG FOR INFO to supporters as they want.
THANK!
Old 01-04-2020, 12:33   #39 (permalink)
Crazy Poster
Member: 714092
Thanks Meter: 11
Operation : Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM15)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.0.8.4
Connecting to phone...OK
Waiting for response...OK
Hardware ID : E1C00800 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Reading Auth Blob...OK
Blob : NDE1MTQxNDE0MTQ0MzA0MjQxNDE0NDVGNEMzOTQzNzY0OTYzNE YzNTQzNkUzMzY2NjUzNTQ3NkY3MzU1NTMzMzQxNTI2ODU1NDc1 MT==
Getting Auth Data...Connecttion to Auth App Failed!
Run Auth App if not running, or restart Auth App!
Storage Initializaton Failed!
Operation Finished.
QcFire Ver. 5.2
Old 01-04-2020, 12:33   #40 (permalink)
hm.faizan's Avatar
Member: 1082907
Sonork: 100.1606954
Thanks Meter: 342
K20 Pro
Device : Xiaomi_No_Auth RedmiK20Pro_Mi9TPro_raphael
Found Port : Qualcomm HS-USB QDLoader 9008 (COM16)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Hardware ID : E1600E00 [E1600E00] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Sending Loader [RedmiK20Pro_Mi9TPro_raphael]...Done
Executing Loader...Failed! Possibly Wrong Loader
Please select Loader manually, or use Factory Loader in Custom Option.
Operation Finished.
QcFire Ver. 5.2
Old 01-04-2020, 13:32   #41 (permalink)
Member: 2245796
Sonork: 100.1604561
Thanks Meter: 20
thnk you very much umt team great updat and Xiaomi qullcomm divce Auth game over big thanks
Old 01-04-2020, 13:38   #42 (permalink)
Member: 2745836
Sonork: @djbeka
Thanks Meter: 17
Operation : Xiaomi Boot Patch
Found Port : Qualcomm HS-USB QDLoader 9008 (COM20)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 5.1.1.2
Hardware ID : E1A00B00 [8953] 00007200
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Sending Loader [Redmi7_onclite]...Done
Operation Finished.
QcFire Ver. 5.2
Old 01-04-2020, 14:12   #43 (permalink)
Member: 2595796
Thanks Meter: 2
Operation : Flash
Port : Qualcomm HS-USB QDLoader 9008 (COM3)
Opening Port...OK
Sending Loader [RedmiNote7_Lavender]...Done
Blob : NDE1MTQxNDE0MTQ0MzA0MjQxNDE0MjU5N0E1MDYyNTY1NDcyND I2QTU1NDY0RTQyNjY2QTc3Nzk1MjQ0Nzk1OTUzNUEzMzQ0NjU3 Nz==
Operation Finished.
Old 01-04-2020, 14:30   #44 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
Operation : Flash
Found Port : Qualcomm HS-USB QDLoader 9008 (COM24)
Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0
Hardware ID : E1600400 [8953] 00000000
Sending Loader [Redmi6Pro_******]...Write Error!
Operation Finished.
QcFire Ver. 5.2
not working
Old 01-04-2020, 15:13   #45 (permalink)
Crazy Poster
Member: 452306
Redmi Note 8 ginkgo
Operation : Flash
Port : Qualcomm HS-USB QDLoader 9008 (COM4)
Opening Port...OK
Hardware ID : E1A01000 [E1A01000] 00007200
Sending Loader [RedmiNote8_ginkgo]...Done
Operation Finished.
QcFire Ver. 5.2
Page generated in 0.26659 seconds with 8 queries
