02-14-2018, 07:16 | #48 (permalink) |
No Life Poster Join Date: Apr 2003 Location: INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | ASUS X00LDA FRP done Device : ASUS X00LDA Operation : Reset FRP Checking for existing devices...Found Port : COM20 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 39A21620 OPK_DATA : FDB379775FEB07C551EFBC01F78CD6ABAC99A2829E6F63768E 4491B32485B6E5 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8937_015.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8937, eMMC, 32 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : asus ASUS_X00LDA [msm8937] Software : NMF26F.WW_Phone-14.0400.1709.165-20170928, WW_Phone-14.0400.1709.165-20170928 [Thu Sep 28 09:01:16 CST 2017] Android Ver. : 7.1.1 |
The Following 2 Users Say Thank You to saif@cellplus For This Useful Post: |
02-20-2018, 11:24 | #52 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | vdf 710 read done Quote:
The Following User Says Thank You to Steve-1 For This Useful Post: |
02-24-2018, 17:50 | #54 (permalink) |
Junior Member Join Date: Aug 2013 Location: unchehra (satna )
Member: 1999073 Status: Offline Sonork: 100.1672641 Thanks Meter: 3 | Hi umt team plz update lg nexus 5x frp remove android 7.1.2 and above Old version 1.7 frp done but not remove I am try on download mode fastboot not work |
02-24-2018, 20:26 | #57 (permalink) |
Member: 2501288 Status: Offline Thanks Meter: 328 | Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM52) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1009900 [8976] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8976_002.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8976, eMMC, 16 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Writing [modem_0.img] -> [modem]...Done Writing [sbl1_0.img] -> [sbl1]...Done Writing [sbl1bak_0.img] -> [sbl1bak]...Done Writing [rpm_0.img] -> [rpm]...Done Writing [rpmbak_0.img] -> [rpmbak]...Done Writing [tz_0.img] -> [tz]...Done Writing [tzbak_0.img] -> [tzbak]...Done Writing [devcfg_0.img] -> [devcfg]...Done Writing [devcfgbak_0.img] -> [devcfgbak]...Done Writing [dsp_0.img] -> [dsp]...Done Writing [sec_0.img] -> [sec]...Done Writing [splash_0.img] -> [splash]...Done Writing [aboot_0.img] -> [aboot]...Done Writing [abootbak_0.img] -> [abootbak]...Done Writing [boot_0.img] -> [boot]...Done Writing [recovery_0.img] -> [recovery]...Done Writing [system_0.img] -> [system]...Done Writing [cache_0.img] -> [cache]...Done Writing [persist_0.img] -> [persist]...Done Writing [misc_0.img] -> [misc]...Done Writing [mdtp_0.img] -> [mdtp]...Done Writing [cmnlib_0.img] -> [cmnlib]...Failed Operation Finished. Module Ver. 1.7 |
02-25-2018, 07:43 | #58 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Try again, and if error on same partition, then most possibly issue with hardware. Alternative method is to untick partition which failed to flash and also those which flashed already, and then Flash again. Br, Ultimate Multi Tool |
