06-06-2018, 20:26 | #18 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Nigeria, Oyo state Age: 48
Member: 180091 Status: Offline Thanks Meter: 62 | I'M TRY TO REMOVE FRP ON MOTOROLA NEXUS 6 AND IT GOT BRICKED ALONG THE LINE, I REPEATED THE OPERATION AND IT TRIED TO UNBRICK, BUT THEN STAYED ON FASTBOOT, I TRIED AGAIN TO REMOVE FRP BUT ALWAYS FAILED TO ENTER EDL MODE. IS THERE ANYWAY I CAN REBOOT TO EDL AND TRY TO UNBRICK AGAIN? OR IS THERE A WAY OUT, KINDLY HELP ME. HERE ARE SOME LOGS: Port : Fastboot Interface Baud Rate : Not Applicable Device : Motorola Nexus6 Operation : FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : 000000000000000 Boot Ver. : moto-apq8084-71.08(*) Baseband : Not Found Software : Not Found IMEI : 000000000000000 CPU : APQ8084 ES1.1 RAM : 3072MB Hynix S8 SDRAM DIE=6Gb EMMC : 32GB Sandisk REV=07 PRV=01 TYPE=57 Preparing Device... Done Cancelled by user! Process failed! Please try again to Unbrick. Operation Failed. Elapsed Time: 00:11 [Module Ver. 5.0] Port : Fastboot Interface Baud Rate : Not Applicable Device : Motorola Nexus6 Operation : FRP Reset Searching for Device in FastBoot Mode... Failed Checking for device in 9008 mode... OK Connecting to device on COM3... OK Initializing Device... Init Error [1] Process failed! Please try again to Unbrick. Operation Failed. Elapsed Time: 00:45 [Module Ver. 5.0] Port : Fastboot Interface Baud Rate : Not Applicable Device : Motorola Nexus6 Operation : FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : 000000000000000 Boot Ver. : moto-apq8084-71.08(*) Baseband : Not Found Software : Not Found IMEI : 000000000000000 CPU : APQ8084 ES1.1 RAM : 3072MB Hynix S8 SDRAM DIE=6Gb EMMC : 32GB Sandisk REV=07 PRV=01 TYPE=57 Preparing Device... Done Could not find phone. Check phone, or install driver if required. Process failed! Please try again to Unbrick. Operation Failed. Elapsed Time: 00:25 [Module Ver. 5.0] |
06-07-2018, 06:33 | #19 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | In first log you cancelled the operation. This is the reason. Now hold power and both volume button for 15 to 30 seconds to that EDL state can reset, then connect phone to PC and check if 9008 port is properly installed. If its properly installed, you can proceed with Unbricking. Br, UMT |
06-07-2018, 16:47 | #20 (permalink) |
Member: 180091 Status: Offline Thanks Meter: 62 | like i said, it's now in fastboot and failled to boot normally, i tried to remove frp and this is what i get. Port : Fastboot Interface Baud Rate : Not Applicable Device : Motorola Nexus6 Operation : FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : 000000000000000 Boot Ver. : moto-apq8084-71.08(*) Baseband : Not Found Software : Not Found IMEI : 000000000000000 CPU : APQ8084 ES1.1 RAM : 3072MB Hynix S8 SDRAM DIE=6Gb EMMC : 32GB Sandisk REV=07 PRV=01 TYPE=57 Preparing Device... Done Could not find phone. Check phone, or install driver if required. Process failed! Please try again to Unbrick. Operation Failed. Elapsed Time: 00:48 [Module Ver. 5.0] Log Saved to Logs\180607_163824.log it failed to enter edl during the frp remove process, what can i do next? i think i need enter edl in order to unbrick. |
06-07-2018, 17:43 | #21 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
06-07-2018, 18:32 | #22 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | And in current status, just flash phone with firmware. You can find it easily on google firmware page. https://developers.google.com/android/images Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
06-09-2018, 02:50 | #25 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
06-09-2018, 13:55 | #27 (permalink) | |
Show me only one Box/tool that allowe of Reset FRP in Last Patch 2018, (from march), w/o Full combination or Sboot or Boot.img....i not know only one. | |
The Following User Says Thank You to allumts For This Useful Post: |
06-10-2018, 14:48 | #28 (permalink) | |
Crazy Poster Join Date: Feb 2014 Location: Ho Chi Minh VN Age: 35
Member: 2127434 Status: Offline Thanks Meter: 24 | Nexus 6 reset frp done Quote:
The Following User Says Thank You to unlock967 For This Useful Post: |
