Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 10-11-2019, 08:58   #76 (permalink)
Registered User
Member: 1084495
Sonork: arfan 36
server offline problm
Old 10-11-2019, 10:21   #77 (permalink)
Member: 219420
Thanks Meter: 78
what about oppo vivo
Old 10-11-2019, 13:19   #78 (permalink)
Member: 2308999
Sonork: 100.1657583
Thanks Meter: 34
hey umt team why you silent
when server will online?
Old 10-11-2019, 16:42   #79 (permalink)
Member: 2683265
How do I check how many credits do I have left?
How to check credit extension
Old 10-11-2019, 16:57   #80 (permalink)
Member: 2683265
How to check after the operation of the remaining credits?
Old 10-11-2019, 19:48   #81 (permalink)
Member: 2308999
Sonork: 100.1657583
Thanks Meter: 34
Originally Posted by mostafa_lock View Post
how do i check how many credits do i have left?
udate to 4.9.1 there is option for check credits
The Following User Says Thank You to askdm7 For This Useful Post:
Old 10-11-2019, 20:59   #82 (permalink)
Member: 2908641
Operation : Repair IMEI
Searching for Device in FTM Mode...Not Found
Port : COM15 : Qualcomm HS-USB Diagnostics 9091 (COM15)
Failed to read Info. Make sure phone is in FTM Mode.
Operation Failed.
QcFire Ver. 4.9
How to set oneplus 6 and 6t on FTM mode?
Old 10-12-2019, 08:26   #83 (permalink)
Member: 780451
Thanks Meter: 43
Product not found!
Product not found!
http://fastunlocking.com/shop/index....&product_id=68
Old 10-12-2019, 11:01   #84 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
Device : OnePlus 7
Operation : Reset FRP
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM10)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.5
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1500A00 [SD855] 85495100
OPK_DATA : 7A44FD44C35394DC10E1B910D525491DA862D0E420FE0BEF04 0FECF30032DA08
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [SD855]...Done
Executing Loader...OK
Detecting Chip Type...OK
DebugData : BAAAABAAAAANAAAAAQAAAA==
Using Alternate Method...
Error getting Payload Information!
Error Log : BAAAABAAAAANAAAAAQAAAA==
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 4.9.1
Old 10-12-2019, 16:23   #85 (permalink)
Member: 2308999
Sonork: 100.1657583
Thanks Meter: 34
where is umt support team can you replay when the server will become online ?
Old 10-12-2019, 21:14   #86 (permalink)
Titan_GSM's Avatar
Member: 2901996
Thanks Meter: 917
Originally Posted by yusufali786 View Post
Device : OnePlus 7
Operation Finished.
QcFire Ver. 4.9.1
Select storage type to UFS at the top right corner.then re try task
The Following User Says Thank You to Titan_GSM For This Useful Post:
Old 10-14-2019, 09:16   #87 (permalink)
Member: 2308999
Sonork: 100.1657583
Thanks Meter: 34
Umt mi auth server and umt support dead?
Old 10-14-2019, 11:18   #88 (permalink)
Member: 540254
Thanks Meter: 30
how to enter oneplus 7 pro diag mode,after last updates doesn't accept *#801# code ,nothing shows up when dialing this code anymore.please hlep
Old 10-15-2019, 09:33   #89 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 97,148
Only dead is, your brain spammer, if you Don t like don't spam here and pls I beg you Don t use it.
Page generated in 0.22927 seconds with 9 queries
