Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 10-08-2019, 07:55   #16 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
"Auth Credits can't fix loader issue, connection issue, display or speaker issue."
HAHAHAHA
The Following User Says Thank You to coolshahul For This Useful Post:
Old 10-08-2019, 08:06   #17 (permalink)
Member: 605925
Thanks Meter: 32
how can repiar imei in flash mode?
Old 10-08-2019, 08:40   #18 (permalink)
Member: 627678
Thanks Meter: 14
Mi Note5 pro old version mi account also asking credits for mi account remove, Is need Credits ?
Old 10-08-2019, 09:09   #19 (permalink)
Member: 627678
Thanks Meter: 14
SAFE FORMATE FS ALSO ASKING AUTH. APP FAILD ERROR
Device : Xiaomi Redmi Note 5 Pro
Operation : Format FS
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM8)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1C00C00 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8996_016]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Reading Auth Blob...OK
Blob : NDE1MTQxNDE0MTQ2NkI0MjQxNDE0Mzc3NEE0RTVGNTk2NDZBNj IzMDc0NkU2Nzc5NkM0Nzc4MzI0ODM3Nzg2NTRBNEU3MzUyNDY2 Nz==
Getting Auth Data...Connecttion to Auth App Failed!
Run Auth App if not running, or restart Auth App!
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 4.9.1
Please check the issue.
Old 10-08-2019, 09:56   #20 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Operation Finished.
QcFire Ver. 4.9.1
Search our section about Note5 Pro and you will find answer.
Br,
UMT
Old 10-08-2019, 13:27   #21 (permalink)
GsmKotla's Avatar
Member: 2016954
Thanks Meter: 345
Vivo Y95 User code FRP done
Device : Vivo Y95
Operation : Vivo Format FS / FRP Reset
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM316)
Opening Port...OK
Hardware ID : E1F00B00 [8937] 00000000
OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2
Sending Loader [8937_029]...Done
Detecting Chip Type...OK
Hardware : 8937, eMMC, 64 GB
LU Count : 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : vivo vivo 1807 [msm8937_64]
Software : OPM1.171019.026 release-keys, eng.compil.20190831.185222 [Sat Aug 31 18:52:22 CST 2019]
Android Ver. : 8.1.0
Patch Level : 2019-09-01
Formatting userdata...Done
Resetting FRP Lock...Done
Wipe cache / userdata from Recovery and reboot.
First startup may take 2-5 minutes.
Operation Finished.
QcFire Ver. 4.9
The Following 2 Users Say Thank You to GsmKotla For This Useful Post:
Old 10-08-2019, 13:42   #22 (permalink)
Member: 2628089
Sonork: 100.1670212
Thanks Meter: 102
UMT Auth Credit Bangladeshi Reseler Need ... I Need Credit Help Me UMT Team Please........
Old 10-08-2019, 17:23   #23 (permalink)
Member: 2476516
Blob : NDE1MTQxNDE0MTQ3Njc0MjQxNDE0MjZDNzk0QjJEMzI1OTc2Nj c1NzM5NTQ1MDRENEM1MjM5Mzg1MzM5NTA2MjMyNEE0OTU0MzQ0 MT==
Requesting UMT Server for Auth Data...OK
Credits Left: 1
Authenticating...OK
Using Alternate Method...
DebugData : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJJTkZPOiBDYWxsaW5nIGhh bmRsZXIgZm9yIGNvbmZpZ3VyZSIgLz48L2RhdGE+PD94bWwgdm Vyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRh Pgo8bG9nIHZhbHVlPSJJTkZPOiBTdG9yYWdlIHR5cGUgc2V0IH RvIHZhbHVlIFVGUyIgLz48L2RhdGE+PD94bWwgdmVyc2lvbj0i MS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIH ZhbHVlPSJFUlJPUjogTkFLOiBIb3N0IHdhbnRzIHRvIHNlbmQg YSBIYXNoIHRhYmxlIDgxOTIgbGFyZ2VyIHRoYW4gc3VwcG9ydG VkIDAiIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIE1lbW9yeU 5hbWU9IlVGUyIgTWluVmVyc2lvblN1cHBvcnRlZD0iMSIgVmVy c2lvbj0iMSIgTWF4UGF5bG9hZFNpemVUb1RhcmdldEluQnl0ZX M9IjEwNDg1NzYiIE1heFBheWxvYWRTaXplVG9UYXJnZXRJbkJ5 dGVzU3VwcG9ydGVkPSIxMDQ4NTc2IiBNYXhYTUxTaXplSW5CeX Rlcz0iNDA5NiIgRGF0ZVRpbWU9IkF1ZyAxNCAyMDE5IC0gMjI6 MDI6MDUiIC8+PC9kYXRhPn==
Error getting Payload Information!
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJJTkZPOiBDYWxsaW5nIGhh bmRsZXIgZm9yIGNvbmZpZ3VyZSIgLz48L2RhdGE+PD94bWwgdm Vyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRh Pgo8bG9nIHZhbHVlPSJJTkZPOiBTdG9yYWdlIHR5cGUgc2V0IH RvIHZhbHVlIFVGUyIgLz48L2RhdGE+PD94bWwgdmVyc2lvbj0i MS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIH ZhbHVlPSJFUlJPUjogTkFLOiBIb3N0IHdhbnRzIHRvIHNlbmQg YSBIYXNoIHRhYmxlIDgxOTIgbGFyZ2VyIHRoYW4gc3VwcG9ydG VkIDAiIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIE1lbW9yeU 5hbWU9IlVGUyIgTWluVmVyc2lvblN1cHBvcnRlZD0iMSIgVmVy c2lvbj0iMSIgTWF4UGF5bG9hZFNpemVUb1RhcmdldEluQnl0ZX M9IjEwNDg1NzYiIE1heFBheWxvYWRTaXplVG9UYXJnZXRJbkJ5 dGVzU3VwcG9ydGVkPSIxMDQ4NTc2IiBNYXhYTUxTaXplSW5CeX Rlcz0iNDA5NiIgRGF0ZVRpbWU9IkF1ZyAxNCAyMDE5IC0gMjI6 MDI6MDUiIC8+PC9kYXRhPn==
QcFire Ver. 4.9.1
Checking for Available Credits....OK
Qcfire use credit but failed, UMT803000512 refund 1 credit please.
Old 10-08-2019, 18:39   #24 (permalink)
Member: 2569104
Thanks Meter: 42
Redmi Note 6 Pro mi acc disabled
Operation : Disable Mi Account
Port : Android HS-USB QDLoader 9008 (COM11)
Driver Info : TCL, qcusbser.sys, 2.1.2.1
Opening Port...OK
Blob : NDE1MTQxNDE0MTQ2NkI0MjQxNDE0NDVGNUY1RjVGNUY2OTUxNz E3MTQzNTE0Rjc3NzQ0MTUzNEI2RDY0MkQ3NzY4MzE3NTczN0E0 MU==
Credits Left: 9
Authenticating...OK
Hardware : MSM8996, eMMC, 64 GB
Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512
Device : Xiaomi Redmi Note 6 Pro [tulip]
Software : OPM1.171019.011, V10.2.2.0.OEKMIXM [Mon Jan 14 20:43:07 WIB 2019]
Patch Level : 2019-01-01
Reading Data...
Preparing Data...Done
Trying to Disable Mi Account...Done
Operation Finished.
QcFire Ver. 4.9.1
The Following User Says Thank You to robertyanta83 For This Useful Post:
Old 10-08-2019, 18:40   #25 (permalink)
Member: 2569104
Thanks Meter: 42
Redmi Note 6 Pro mi acc disabled!!!
Thanks UMT Team
Opening Port...OK
Credits Left: 9
Authenticating...OK
Reading Data...
Operation Finished.
QcFire Ver. 4.9.1
The Following 2 Users Say Thank You to robertyanta83 For This Useful Post:
Old 10-08-2019, 20:27   #26 (permalink)
U.M.T's Avatar
Member: 2465108
Credits Left: 1
Authenticating...OK
QcFire Ver. 4.9.1
Which model is this?
Please make a separate thread with screenshot of error msg which must show Blob also.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 10-08-2019, 22:27   #27 (permalink)
Member: 1610674
Sonork: 210921
Thanks Meter: 217
Originally Posted by vuduongthanh View Post
Please update my credit. A pay via paypal but check in tool : No credit! My serrial UMT9************
don't post here your card no unless asked by support it will be blocked
The Following User Says Thank You to okello For This Useful Post:
Old 10-09-2019, 03:01   #28 (permalink)
Member: 2367218
Thanks Meter: 20
Hello team we buy credit from server so it has account for Mi umt server ?
The Following User Says Thank You to Ravuthcambo For This Useful Post:
Old 10-09-2019, 04:33   #29 (permalink)
Member: 1878634
Sonork: 100.1602000
Thanks Meter: 9
nice update umt team
Old 10-09-2019, 08:05   #30 (permalink)
Member: 1989771
how use server authorized flash xiaomi mi 9 with edl mode ? i had 10 credit
Page generated in 2.07025 seconds with 8 queries
