10-09-2019, 12:21 | #31 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Earth
Member: 2620603 Status: Offline Thanks Meter: 40 | Operation : Disable Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NkI0MjQxNDE0MjQ3NjUyRDQ1MzgzOTZBMz U1MTQ1Nzc2NzY5NDU3NDY5MzQ1NDVBNTk0MTYxNTg2NTZGNTM0 MT== Requesting UMT Server for Auth Data...OK Credits Left: 9 Authenticating...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro [tulip] Software : OPM1.171019.011, V10.2.2.0.OEKMIXM [Mon Jan 14 20:43:07 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-01-01 USERDATA : Encrypted Disabling Android Locks...Done Operation Finished. QcFire Ver. 4.9.1 but phone still locked |
10-09-2019, 12:36 | #32 (permalink) |
Member: 2620603 Status: Offline Thanks Meter: 40 | Device : Xiaomi Redmi Note 6 Pro Operation : Disable Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NkI0MjQxNDE0MjQ3NjUyRDQ1MzgzOTZBMz U1MTQ1Nzc2NzY5NDU3NDY5MzQ1NDVBNTk0MTYxNTg2NTZGNTM0 MT== Requesting UMT Server for Auth Data...OK Credits Left: 9 Authenticating...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro [tulip] Software : OPM1.171019.011, V10.2.2.0.OEKMIXM [Mon Jan 14 20:43:07 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-01-01 USERDATA : Encrypted Disabling Android Locks...Done Operation Finished. QcFire Ver. 4.9.1 but phone still locked Last edited by red5ive; 10-09-2019 at 12:37. Reason: delete this post please |
10-09-2019, 15:17 | #33 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1631414 Status: Offline Thanks Meter: 1 | unloco mi account redmi note 7 tested redmi note 7 lavander, unlock account mi ok. only after unlocking and releasing anti-relock and reconnecting it again asks for an account. would be the correct procedure |
10-10-2019, 16:08 | #36 (permalink) |
Freak Poster Join Date: Sep 2006 Location: india, karnataka, bellary
Member: 358717 Status: Offline Sonork: 100.1648649 Thanks Meter: 44 | Device : Xiaomi Redmi Note 7 Operation : Disable Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM30) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00B00 [8953] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_027]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2MzA0MjQxNDE0MzRBMzM2NjJEMzg0QzU5Nk M1NjU4Mzk0MjQ2NUE1NDMyNjk1MDM2NDQ1OTQ4MzI0RjRENzQ3 Nz== Requesting UMT Server for Auth Data...Server Offline(1) Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.9.1 |
10-11-2019, 06:58 | #40 (permalink) |
Major Poster Join Date: Aug 2013
Member: 1997780 Status: Offline Thanks Meter: 6 | I think,the worst update i've ever seen with UMT looks this credit based is not a fair solution,as we know that umt and m*t are the best tools in our gsm field m*t makes an update with modified f/w for unlock some oppo devices and the user report says that this update is flop hope umt will develop an update without credit based |
10-11-2019, 13:04 | #43 (permalink) | |
Junior Member Join Date: Nov 2007 Location: Kyrgyzstan
Member: 635046 Status: Offline Thanks Meter: 10 | Quote:
Code: Operation : Wipe EFS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr.mbn]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTUwNkI2OTQxNDE0NDRENEUzODRFNjc1NDMzMzA3MTUwMzIzMzc0NTc2ODMxNkM0NDVGNjYzNzM1NDE2OTYyNzk2Nz== Requesting UMT Server for Auth Data...No Credits Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.9.1 | |
10-11-2019, 20:02 | #45 (permalink) |
Insane Poster Join Date: Mar 2010 Location: GHURKA BELTOLA,SIRAJGONJ ,BD
Member: 1265808 Status: Offline Sonork: 1660165 Thanks Meter: 21 | Redmi note 7 pro min account remove failed by system data missing but no refund my 1 credits . Please answer umt team ? |
The Following User Says Thank You to mr_ashiq For This Useful Post: |
