07-08-2019, 13:51 | #31 (permalink) | ||
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | ||
07-08-2019, 13:53 | #32 (permalink) | |
Br, UMT | |
The Following User Says Thank You to U.M.T For This Useful Post: |
07-08-2019, 14:02 | #33 (permalink) | ||
I think you should work for free bcoz your tools have paid you more than their cost. Quote:
Hahahaa, you repair phones but still cant not find a single mi account id? Ooops! Why you bother to buy activation at first place if no benefit is there. | ||
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
07-08-2019, 14:20 | #34 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Rayer Bazar, Dhaka-1209 Age: 34
Member: 1414328 Status: Offline Sonork: 100.1619742 Thanks Meter: 148 | Super Update Mi FRP Remove need Mi Auth account Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM111) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAPkiAABzPfBgUb4hXdwmT5DPWVdCO4AkOA Getting Auth Data...Auth App Not Running! Run App by click Auth App button. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.4 Device : Xiaomi Mi A2 Lite Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM111) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAPkiAABzPfBgnHcDt-ZWBSFrs06XoKVRTQ Getting Auth Data...Auth App Not Running! Run App by click Auth App button. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.4 |
07-08-2019, 14:40 | #36 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
The Following 2 Users Say Thank You to Franky_36 For This Useful Post: |
07-08-2019, 14:50 | #37 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i buy umt pro dongle before some days and install all setups.. can i use huawei suit free... if no then is this useless for huwaei thanks |
07-08-2019, 16:04 | #38 (permalink) |
Insane Poster Join Date: Aug 2012 Location: Azerbaijan Age: 34
Member: 1795410 Status: Offline Sonork: 484817 Thanks Meter: 9 | Make sure u.m.t team are doing good updates. Qcfire 4.4 in the last update that you need to run auth app? I have updated qcfire 4.4 problem. qcfire 4.4 erased back to 4.3. I'm reading in the forum this run auth app has been disturbed by the protector. we ask you to give a fair opinion and solve this problem. I was very uncomfortable because of this update 1 single run auth app for. I would appreciate it if you wrote how and how to use it. I expect 1 satisfactory answer from you as soon as possible. |
07-08-2019, 16:08 | #40 (permalink) |
Member: 1795410 Status: Offline Sonork: 484817 Thanks Meter: 9 | u.m.t team qcfire 4.4 run auth what is the app tell me what it works? and how should we use this __ Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob ... OK Blob: AQAAAPkiAABzPfBgnHcDt-ZWBSFrs06XoKVRTQ Getting Auth Data ... Not Running Auth App! Run App by click Auth App button. Storage Initializaton Failed! USB port / cable. Operation Finished. QcFire Ver. 4.4 let's not face the problem |
07-08-2019, 17:22 | #42 (permalink) |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | xiaomi MI8 dipper not flash need account autorize Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [SD845] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_sdm845_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAEEBAAA8go8Y9Pk3N6BAZ0kwEW7dFZN9IA Getting Auth Data...Failed! Access denied! Please check if your Mi Service Account is authorized . Or please restart Auth App. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. br treo29 |
