01-12-2019, 12:15 | #32 (permalink) |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | at this time umt is the only team to support many devices and many operations and provides many many exclusive updates big thanx to umt team keep it up |
01-27-2019, 12:58 | #37 (permalink) |
Junior Member Join Date: Dec 2013 Location: bangladesh
Member: 2088762 Status: Offline Sonork: [email protected] Thanks Meter: 1 | plz read mtk firmware option |
02-03-2019, 13:33 | #38 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | LG D295F Firmware Extractor - Error Division by Zero LG D295F Firmware Extractor - Error Division by Zero Hi I am trying extract firmware for use QC Fire and repair boot (But i alway got this error Division by Zero. |
The Following User Says Thank You to mcdiniz For This Useful Post: |
02-03-2019, 14:14 | #39 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | UltimateLG V0.3 no error Division by zero Hi For version 03 is working good Code: Filename : D295f10d_0.dz Model : LG-D295 Version : D295f10d Extracting PrimaryGPT_0.bin ...Done Extracting modem_8192.bin ...Done Extracting sbl1_139264.bin ...Done Extracting rpm_141312.bin ...Done Extracting tz_142336.bin ...Done Extracting sdi_143360.bin ...Done Extracting aboot_144384.bin ...Done Extracting rpmb_148480.bin ...Done Extracting tzb_149504.bin ...Done Extracting abootb_150528.bin ...Done Extracting persist_204800.bin ...Done Extracting laf_270336.bin ...Done Extracting boot_319488.bin ...Done Extracting recovery_364544.bin ...Done Extracting factory_475136.bin ...Done Extracting sbl1b_581632.bin ...Done Extracting cust_655360.bin ...Done Extracting BackupGPT_7633920.bin ...Done Extract Path : E:\FLASH FILES 2019\jan 2019\fev 2019\D295F\ XML File : E:\FLASH FILES 2019\jan 2019\fev 2019\D295F\rawprogram0.xml Time taken: 00:01 [Module Ver. 0.3] Log Saved to Logs\190203_111102.log |
02-06-2019, 01:20 | #40 (permalink) |
Insane Poster Join Date: Feb 2016 Location: Honduras Age: 28
Member: 2529300 Status: Offline Thanks Meter: 37 | Code: Port : COM131 : LGE AndroidNet USB Serial Port (COM131) Baud Rate : 115200 - Auto Device : LG *Automatic* Operation : Write Firmware Opening Port...OK Reading Information...OK Model : LGLS450 PID : IMEI : 3568480 Firmware : LS450ZV7 Factory Ver. : LS450ZV7_00 LAF Ver. : 1.1 Chipset : msm8909 Operator : SPR Country : US Memory ID : H8G1e Capacity : 7.28 GB Battery : 99% Loading ULF Firmware...Loaded 98 Partition(s) Model : LGLS450 Version : LS450ZV7_00 Sector Size : 0x0200 Reading Partition Table...OK Setting Parameters...Done Formatting [userdata]...Done Formatting [encrypt]...Done Writing 01 of 98 [PrimaryGPT]...Done Writing 02 of 98 [modem]...Done Writing 03 of 98 [sbl1]...Done Writing 04 of 98 [tz]...Done Writing 05 of 98 [rpm]...Done Writing 06 of 98 [aboot]...Done Writing 07 of 98 [sbl1bak]...Done Writing 08 of 98 [tzbak]...Done Writing 09 of 98 [rpmbak]...Done Writing 10 of 98 [abootbak]...Done Writing 11 of 98 [modemst1]...Done Writing 12 of 98 [modemst2]...Done Writing 13 of 98 [ssd]...Done Writing 14 of 98 [DDR]...Done Writing 15 of 98 [fsg]...Done Writing 16 of 98 [fsc]...Done Writing 17 of 98 [sec]...Done Writing 18 of 98 [keystore]...Done Writing 19 of 98 [encrypt]...Done Writing 20 of 98 [eksst]...Done Writing 21 of 98 [devinfo]...Failed Operation Failed. Time taken: 00:39 [UltimateLG v0.4] |
02-06-2019, 23:26 | #41 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | LG D385 Write Flash Done LG D385 Write Flash Done Code: Port : COM8 : LGE Mobile USB Serial Port (COM8) Baud Rate : 115200 - Auto Device : LG *Automatic* Operation : Write Firmware Opening Port...OK Reading Information...OK Model : LG-D385 PID : IMEI : 353022062146854 Firmware : D38510c Factory Ver. : LGD385AT-00-V10a-724-31-APR-04-2014+3 LAF Ver. : 1.0 Chipset : msm8610 Operator : GLOBAL Country : SCA Memory ID : H8G2d Capacity : 7,28 GB Battery : 74% Analyzing KDZ Firmware... Loading DZ Firmware...Loaded 37 Partition(s) Model : LG-D385 Version : D38510e Sector Size : 0x0000 Reading Partition Table...OK Setting Parameters...Done Formatting [userdata]...Done Formatting [encrypt]...Done Writing 01 of 37 [PrimaryGPT]...Done Writing 02 of 37 [modem]...Done Writing 03 of 37 [sbl1]...Done Writing 04 of 37 [rpm]...Done Writing 05 of 37 [tz]...Done Writing 06 of 37 [sdi]...Done Writing 07 of 37 [aboot]...Done Writing 08 of 37 [rpmb]...Done Writing 09 of 37 [tzb]...Done Writing 10 of 37 [abootb]...Done Writing 11 of 37 [persist]...Done Writing 12 of 37 [laf]...Done Writing 13 of 37 [boot]...Done Writing 14 of 37 [recovery]...Done Writing 15 of 37 [factory]...Done Writing 16 of 37 [sbl1b]...Done Writing 17 of 37 [cust]...Done Writing 18 of 37 [system]...Done Writing 19 of 37 [system]...Done Writing 20 of 37 [system]...Done Writing 21 of 37 [system]...Done Writing 22 of 37 [system]...Done Writing 23 of 37 [system]...Done Writing 24 of 37 [system]...Done Writing 25 of 37 [system]...Done Writing 26 of 37 [system]...Done Writing 27 of 37 [system]...Done Writing 28 of 37 [system]...Done Writing 29 of 37 [system]...Done Writing 30 of 37 [system]...Done Writing 31 of 37 [system]...Done Writing 32 of 37 [system]...Done Writing 33 of 37 [system]...Done Writing 34 of 37 [system]...Done Writing 35 of 37 [system]...Done Writing 36 of 37 [system]...Done Writing 37 of 37 [BackupGPT]...Done Reading Partition Table...OK Formatting [mpt]...Done Finalizing Parameters...Done Rebooting Device...Done Operation Finished. Time taken: 16:41 [UltimateLG v0.4] Log Saved to Logs\190206_195636.log |
