02-17-2019, 14:38 | #52 (permalink) |
Freak Poster Join Date: Nov 2016 Location: karachi
Member: 2650777 Status: Offline Sonork: 100.650600 Thanks Meter: 161 | Brand : Oppo Model : F3 (CPH1609) Operation : Read Pattern Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM29) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connecting to HighSpeed Port... Waiting for HighSpeed Port.. Port : MediaTek DA USB VCOM (Android) (COM35) Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : OPPO Manufacturer : OPPO Model : CPH1609 Prod. Name : CPH1609 Device : CPH1609 Board : full_oppo6750_16391 Platform : mt6750 Android Ver. : 6.0 Display ID : CPH1609EX_11_A.24_180805 Patch Level : 2018-06-05 Userdata is ENCRYPTED Encrypted Userdata is not Supported! Disconnect Battery/Cable and Power On Phone. [Ver. 1.7] |
02-18-2019, 12:59 | #54 (permalink) |
Insane Poster Join Date: Sep 2013 Location: pattukkottai tamilnadu
Member: 2036114 Status: Offline Thanks Meter: 5 | Device : 1601 Board : mt6750 Platform : mt6750 Android Ver. : 7.0 Display ID : NRD90M release-keys Patch Level : 2018-10-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.7] |
02-18-2019, 13:01 | #55 (permalink) |
Member: 2036114 Status: Offline Thanks Meter: 5 | Brand : Vivo Model : V5s Operation : Format FS (Advance) Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM63) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connecting to HighSpeed Port... Waiting for HighSpeed Port.. Port : MediaTek DA USB VCOM (Android) (COM50) Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : vivo Manufacturer : vivo Model : vivo 1601 Prod. Name : 1601 Device : 1601 Board : mt6750 Platform : mt6750 Android Ver. : 7.0 Display ID : NRD90M release-keys Patch Level : 2018-10-05 Userdata is ENCRYPTED Formatting userdata... Format Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.7] |
02-18-2019, 20:58 | #56 (permalink) | |
Junior Member Join Date: Aug 2013 Location: Larkana Sindh
Member: 2000601 Status: Offline Thanks Meter: 3 | Quote:
Port : COM25 : FC - PC UI Interface (COM25) Baud Rate : 921600 Device : Huawei E8231 Operation : Write Firmware Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E8231 Revision : 22.618.11.01.306 IMEI : 862869024221371 Build : Dec 16 2014, 20:47:28 Software : 22.618.11.01.306 Dashbaord : WEBUI_17.100.05.06.306 Hardware : CH1E8231SM Flash Code : 52047422 Firmware : [V001] [E8231] [22.618.01.02.910] Partitions : 9 Preparing Device... OK Setting Download Mode... OK Waiting for Device... OK Port Found : COM25 : FC - PC UI Interface (COM25) Opening Port... OK Checking Device... OK Validating Boot Mode... OK Bootloader : 7200B--SKCBADZM Device : HUAWEI E8231 Starting Flashing Process... Writing Partition... [0x00000100]... OK Writing Partition... [0x00000101]... OK Writing Partition... [0x00000102]... OK Writing Partition... [0x00550103]... OK Writing Partition... [0x00000104]... OK Writing Partition... [0x00000105]... OK Writing Partition... [0x00000107]... OK Writing Partition... [0x00000108]... OK Writing Partition... [0x00000066]... OK Waiting for Modem... . . . . . . . Failed Port Closed. Operation Finished. Elapsed Time: 01:37 [Module Ver. 5.2] Log Saved to Logs\190219_005244.log why my moden not truning on and giving error | |
02-18-2019, 21:17 | #57 (permalink) |
Member: 2000601 Status: Offline Thanks Meter: 3 | hello UMT Team Port : COM25 : FC - PC UI Interface (COM25) Baud Rate : 921600 Device : Huawei E8231 Operation : Write Firmware Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E8231 Revision : 22.618.11.01.306 IMEI : 862869024221371 Build : Dec 16 2014, 20:47:28 Software : 22.618.11.01.306 Dashbaord : WEBUI_17.100.05.06.306 Hardware : CH1E8231SM Flash Code : 52047422 Firmware : [V001] [E8231] [22.618.01.02.910] Partitions : 9 Preparing Device... OK Setting Download Mode... OK Waiting for Device... OK Port Found : COM25 : FC - PC UI Interface (COM25) Opening Port... OK Checking Device... OK Validating Boot Mode... OK Bootloader : 7200B--SKCBADZM Device : HUAWEI E8231 Starting Flashing Process... Writing Partition... [0x00000100]... OK Writing Partition... [0x00000101]... OK Writing Partition... [0x00000102]... OK Writing Partition... [0x00550103]... OK Writing Partition... [0x00000104]... OK Writing Partition... [0x00000105]... OK Writing Partition... [0x00000107]... OK Writing Partition... [0x00000108]... OK Writing Partition... [0x00000066]... OK Waiting for Modem... . . . . . . . Failed Port Closed. Operation Finished. why not tuning on my dongle after that |
02-19-2019, 16:34 | #58 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Second, you have not posted any details, simple reason for it is, that you may have use wrong firmware. Br, UMT | |
