03-13-2018, 07:03 | #18 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
We will try to add in next update. Br, Ultimate Multi Tool | |
03-14-2018, 12:17 | #22 (permalink) | |
Freak Poster Join Date: Oct 2007
Member: 619251 Status: Offline Thanks Meter: 19 | Quote:
03-17-2018, 11:37 | #25 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Closing Session... Finalization Error Operation Finished. j7 max Operation: Flash Firmware Port: COM3 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: MTK6757 [HiSpeed] Sending Partition [BOOTLOADER]... Done Sending Partition [lk]... Done Sending Partition [tee1]... Done Sending Partition [PARAM]... Done Sending Partition [efuse]... Done Sending Partition [boot]... Done Sending Partition [recovery]... Done Sending Partition [system]... Done Sending Partition [md1img]... Done Sending Partition [cache]... Done Closing Session... Finalization Error Operation Finished. Elapsed Time: 02:23 [Ultimate Samsung Flasher v1.3] Closing Session... Finalization Error Operation Finished. j7 max Operation: Flash Firmware Port: COM3 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: MTK6757 [HiSpeed] Sending Partition [BOOTLOADER]... Done Sending Partition [lk]... Done Sending Partition [tee1]... Done Sending Partition [PARAM]... Done Sending Partition [efuse]... Done Sending Partition [boot]... Done Sending Partition [recovery]... Done Sending Partition [system]... Done Sending Partition [md1img]... Done Sending Partition [cache]... Done Closing Session... Finalization Error Operation Finished. Elapsed Time: 02:23 [Ultimate Samsung Flasher v1.3 security error this phone has been flashed with unauthorized softwere and locked callyourmobile operator for additionl support, please note that ripair/return for this issue may have additional cost plz help frp lock Device: Samsung Device Operation: Reset FRP (New Method) Port: COM3 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: MTK6757 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Binary Blocked! Failed to reset FRP.! Possibly unsupported firmware, flash phone and try agaiin Elapsed Time: 00:10 [Ultimate Samsung Flasher v1.3] Last edited by U.M.T; 03-17-2018 at 18:21. |
03-17-2018, 14:53 | #26 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | oppo r11s frp failure Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM8) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 00005100 OPK_DATA : 5C7D0E0F4D5796B40D7399F476CA476FD14D27E871F6F59734 CA4F5236ACA2AA Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8976_011.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 1.9 |
03-17-2018, 15:11 | #27 (permalink) |
Crazy Poster Join Date: Dec 2009
Member: 1183467 Status: Offline Sonork: jajula Thanks Meter: 12 | lg q6 frp fail Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : HS-USB Diagnostics 9008 (COM12) Driver Info : Mobile, qcusbser.sys, 2.1.0.3 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00003100 OPK_DATA : 7C7CA65B193D8639CD1237A2AA4CB023AFAE64668B7D81759A 5A64905F15E307 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8937_003.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 1.9 |
03-17-2018, 18:23 | #28 (permalink) | |
If phone can turn on normally, then connect in Normal Mode and try New Method FRP Reset, and post log and details in separate thread. This is update thread, so must be about this update related things only. Br, Ultimate Multi Tool | |
03-17-2018, 18:24 | #29 (permalink) | |
