Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 07-12-2019, 14:59   #16 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Originally Posted by tomelich View Post
I have a doubt I hope you can guide me
for example
Note 7 remove my acc, successful process
After that, there is no re blocking?
can i put another xiaomi account without problems?
You may try after unlocking bootloader.
Br,
UMT
Old 07-12-2019, 16:44   #17 (permalink)
Member: 2227538
Thanks Meter: 30
any update on this redmi note 5 pro wifi after mi acc
Old 07-12-2019, 19:30   #18 (permalink)
Member: 2799881
Thanks Meter: 9
remember also samsung devices, frp lock remove android > 6.0 and also network unlock function for different devices!
Old 07-12-2019, 21:02   #19 (permalink)
tharakax1's Avatar
Member: 2363369
Thanks Meter: 95
pocophone f1 Mi acc support?..
Old 07-12-2019, 21:44   #20 (permalink)
Al-Magic's Avatar
Member: 2189966
Sonork: 100.1653836
Thanks Meter: 164
- EDL Authentication using Xiaomi Auth App (Service Account Required) - NEW!!!
wowo
Old 07-13-2019, 04:42   #21 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 928
Old 07-13-2019, 06:43   #22 (permalink)
Member: 2336297
Sonork: akashkakon
Thanks Meter: 27
UMT Team
Plz Add Xioami Fastboot Bootloader Unlock
All Update Model.
Run Auth App I Dont Know Login Id Pass
How To Login Run Auth App??
And Also Thanks For Update
Old 07-13-2019, 07:44   #23 (permalink)
Member: 2596094
Thanks Meter: 83
Originally Posted by akash.link View Post
UMT Team
All Update Model.
click run auth file and register thats it
Old 07-13-2019, 08:10   #24 (permalink)
shahinbangla's Avatar
Member: 2318480
Sonork: 100.1669259
Thanks Meter: 198
Goood update team But redmi note 7 pro (violet) not support
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM19)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Connecting to phone...OK
Waiting for response...Ignored
Init Handshake Sequence...OK
Hardware ID : E1500900 [E1500900] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Initializing Protocol...OK
Using Auto Loader Selection [0]
CPU not found in database.
Operation Finished.
QcFire Ver. 4.5
Old 07-13-2019, 09:17   #25 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Thanks UMT Team for Bug fixed continue like this
Allumts
Old 07-13-2019, 09:26   #26 (permalink)
Member: 2601652
Sonork: nytman
Device : Xiaomi Redmi Note 7
Operation : Reset Mi Account
Found Port : Qualcomm HS-USB QDLoader 9008 (COM4)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0
Waiting for response...OK
Hardware ID : E1C00800 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8996_022]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Reading Auth Blob...Not Found!
DebugData : AAAAAAAAAAAAAAAAAA==
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Finished.
Old 07-13-2019, 09:27   #27 (permalink)
Member: 2601652
Sonork: nytman
DebugData : AAAAAAAAAAAAA==
Operation Finished.
Solution plz
Old 07-13-2019, 09:51   #28 (permalink)
Member: 1781818
Sonork: 100.1652308:ashaq
Thanks Meter: 130
No dear it is not normal account you need service centre account
Old 07-13-2019, 10:12   #29 (permalink)
Member: 2119732
Thanks Meter: 22
Found Port : Qualcomm HS-USB QDLoader 9008 (COM10)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.9.6
DebugData :
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA A==
Operation Finished.
QcFire Ver. 4.5
you can help me.Thank you
Old 07-13-2019, 10:58   #30 (permalink)
Member: 2834742
redmi s2 botlodar unlock done
The Following User Says Thank You to joyminto For This Useful Post:
Page generated in 0.22722 seconds with 8 queries
