07-18-2019, 04:09 | #51 (permalink) |
Major Poster Join Date: Jun 2017 Location: Chile Age: 34
Member: 2726927 Status: Offline Thanks Meter: 6 | Hello team I receive this error for any operation, my device is new bought in store use the auth app, link a My account of which I am owner, help please. Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM23) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAD0BAABpRBhxuACU1Qc_WGvcFe4M69QZOw Getting Auth Data...Failed! Access denied! Please check if your Mi Service Account is authorized . Or please restart Auth App. Storage Initializaton Failed! Please use correct loader and check USB port / cable. QcFire Ver. 4.5 |
07-20-2019, 12:48 | #53 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2677316 Status: Offline Thanks Meter: 12 | Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr.mbn]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAPkiAAAwZ5zCVqenNMFMho1VnBPaiEBrjw Getting Auth Data...Failed! Access denied! Please check if your Mi Service Account is authorized . Or please restart Auth App. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.5 |
07-20-2019, 19:18 | #55 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: lisbon
Member: 1917749 Status: Offline Thanks Meter: 90 | Quote:
The Following User Says Thank You to anamul123 For This Useful Post: |
07-22-2019, 00:03 | #57 (permalink) |
Junior Member Join Date: Oct 2007 Location: Ukraine
Member: 604267 Status: Offline Thanks Meter: 2 | Operation : Bootloader Unlock/Relock Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAFkBAACJtPhNX5h05eLFHv0FAgoEGBtDVg Getting Auth Data...Failed! Access denied! Please check if your Mi Service Account is authorized . Or please restart Auth App. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.5 |
07-22-2019, 00:04 | #58 (permalink) |
Member: 604267 Status: Offline Thanks Meter: 2 | Operation : Bootloader Unlock/Relock Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAFkBAACJtPhNO9s-utCSjyJpJx0kdnROZQ Getting Auth Data...OK Authenticating...OK Detecting Chip Type...OK Using Alternate Method... Hardware : MSM8996, eMMC, ERASED GPT Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK SYSTEM partition is missing! Missing Data! Operation Finished. QcFire Ver. 4.5 |
07-22-2019, 06:56 | #60 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Karaganda
Member: 1064203 Status: Offline Thanks Meter: 53 | Why i cant flashing MI max 3? Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM1692) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAFkBAADfcWwuCGxpiRN8jDpaE4PLBG41ow Getting Auth Data...Failed! Access denied! Please check if your Mi Service Account is authorized . Or please restart Auth App. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. |
