Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 05-13-2017, 08:40   #31 (permalink)
Member: 2528453
Sonork: Gsm unlock
Thanks Meter: 62
Good update UMT team ...pls add new securety frp sulution
The Following User Says Thank You to deshmukh007 For This Useful Post:
Old 05-13-2017, 09:48   #32 (permalink)
Member: 432679
Thanks Meter: 118
kindly give update for asus phone...frp
if possible
regards!
The Following 2 Users Say Thank You to syed.n For This Useful Post:
Old 05-13-2017, 13:30   #33 (permalink)
Member: 1418143
Thanks Meter: 353
few days ago tried this phone, others tool failed included ur too . but update fix it
Operation : Read Firmware
Checking for existing devices... Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM218)
Driver Info : ZTE Corporation, zghsser.sys, 5.2104.1.2
Connecting to phone... OK
Waiting for response... OK
Init Handshake Sequence... OK
Hardware ID : E1B09000 [8936] 11004200
Initializing Protocol... OK
Using Auto Selection
Preparing Firehose Loader... Done
Sending Loader [8936_3.ufl]... Done
Executing Loader... OK
Hardware : 8936, eMMC, 16 GB
Warning! High Speed Driver not installed.
Please install driver from QcFire\Drivers folder.
Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512
Reading Partition Table... OK
Reading Device Information... OK
Device : TCL 6045Y [msm8916]
Software : LRX22G release-keys, v7ST2-0 [Mon Dec 14 13:26:46 CST 2015]
Android Ver. : 5.0.2
Reading [modem]... Done
Reading [tunning]... Done
Reading [traceability]... Done
Reading [fsc]... Done
Reading [ssd]... Done
Reading [sbl1]... Done
Reading [sbl1bak]... Done
Reading [rpm]... Done
Reading [rpmbak]... Done
Reading [tz]... Done
Reading [tzbak]... Done
Reading [hyp]... Done
Reading [hypbak]... Done
Reading [modemst1]... Done
Reading [modemst2]... Done
Reading [simlock]... Done
Reading [persistent]... Done
Reading [splash]... Done
Reading [tctpersist]... Done
Reading [hdcp]... Done
Reading [DDR]... Done
Reading [fsg]... Done
Reading [sec]... Done
Reading [aboot]... Done
Reading [abootbak]... Done
Reading [boot]... Done
Reading [recovery]... Done
Reading [system]... Done
Reading [persist]... Done
Reading [fota]... Done
Reading [cache]... Done
Reading [misc]... Done
Reading [keystore]... Done
Reading [config]... Done
Reading [PrimaryGPT]... Done
Reading [BackupGPT]... Done
Saved to : C:\UMTool\QcFire\Read\6045Y_LRX22G release-keys_5.0.2\
Operation Finished.
The Following 4 Users Say Thank You to psytr0nic For This Useful Post:
Old 05-13-2017, 17:00   #34 (permalink)
.::RanjitSinh::.'s Avatar
Member: 517102
Sonork: 100.1601229
Thanks Meter: 199
great UMT, keep hard work...best tool i have ever used....Thanks Alot...
The Following User Says Thank You to .::RanjitSinh::. For This Useful Post:
Old 05-14-2017, 00:03   #35 (permalink)
Member: 2078045
Thanks Meter: 151
LENNOVO K5 FULL FLASHING
Operation : Flash
Found Port
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Hardware ID : E1B09000 [8936] 01000100
Sending Loader [8936_1.ufl]... Done
Writing [NON-HLOS.bin] -> [modem] ... Done
Writing [sbl1.mbn] -> [sbl1] ... Done
Writing [sbl1.mbn] -> [sbl1bak] ... Done
Writing [emmc_appsboot.mbn] -> [aboot] ... Done
Writing [emmc_appsboot.mbn] -> [abootbak] ... Done
Writing [rpm.mbn] -> [rpm] ... Done
Writing [rpm.mbn] -> [rpmbak] ... Done
Writing [tz.mbn] -> [tz] ... Done
Writing [tz.mbn] -> [tzbak] ... Done
Writing [hyp.mbn] -> [hyp] ... Done
Writing [hyp.mbn] -> [hypbak] ... Done
Writing [splash.img] -> [splash] ... Done
Writing [S82918F1_Online_V015.img] -> [fsg] ... Done
Writing [sec.dat] -> [sec] ... Done
Writing [boot.img] -> [boot] ... Done
Writing [system_1.img] -> [system] ... Done
Writing [system_2.img] -> [system] ... Done
Writing [system_3.img] -> [system] ... Done
Writing [system_4.img] -> [system] ... Done
Writing [system_5.img] -> [system] ... Done
Writing [system_6.img] -> [system] ... Done
Writing [system_7.img] -> [system] ... Done
Writing [system_8.img] -> [system] ... Done
Writing [system_9.img] -> [system] ... Done
Writing [system_10.img] -> [system] ... Done
Writing [system_11.img] -> [system] ... Done
Writing [system_12.img] -> [system] ... Done
Writing [system_13.img] -> [system] ... Done
Writing [system_14.img] -> [system] ... Done
Writing [system_15.img] -> [system] ... Done
Writing [system_16.img] -> [system] ... Done
Writing [system_17.img] -> [system] ... Done
Writing [system_18.img] -> [system] ... Done
Writing [system_19.img] -> [system] ... Done
Writing [system_20.img] -> [system] ... Done
Writing [system_21.img] -> [system] ... Done
Writing [system_22.img] -> [system] ... Done
Writing [system_23.img] -> [system] ... Done
Writing [system_24.img] -> [system] ... Done
Writing [system_25.img] -> [system] ... Done
Writing [system_26.img] -> [system] ... Done
Writing [system_27.img] -> [system] ... Done
Writing [system_28.img] -> [system] ... Done
Writing [system_29.img] -> [system] ... Done
Writing [system_30.img] -> [system] ... Done
Writing [system_31.img] -> [system] ... Done
Writing [system_32.img] -> [system] ... Done
Writing [system_33.img] -> [system] ... Done
Writing [system_34.img] -> [system] ... Done
Writing [system_35.img] -> [system] ... Done
Writing [system_36.img] -> [system] ... Done
Writing [system_37.img] -> [system] ... Done
Writing [persist_1.img] -> [persist] ... Done
Writing [cache_1.img] -> [cache] ... Done
Writing [cache_2.img] -> [cache] ... Done
Writing [cache_3.img] -> [cache] ... Done
Writing [cache_4.img] -> [cache] ... Done
Writing [cache_5.img] -> [cache] ... Done
Writing [recovery.img] -> [recovery] ... Done
Writing [userdata_1.img] -> [userdata] ... Done
Writing [userdata_2.img] -> [userdata] ... Done
Writing [userdata_3.img] -> [userdata] ... Done
Writing [userdata_4.img] -> [userdata] ... Done
Writing [userdata_5.img] -> [userdata] ... Done
Writing [userdata_6.img] -> [userdata] ... Done
Writing [userdata_7.img] -> [userdata] ... Done
Writing [userdata_8.img] -> [userdata] ... Done
Writing [userdata_9.img] -> [userdata] ... Done
Writing [userdata_10.img] -> [userdata] ... Done
Writing [userdata_11.img] -> [userdata] ... Done
Writing [userdata_12.img] -> [userdata] ... Done
Writing [userdata_13.img] -> [userdata] ... Done
Writing [userdata_14.img] -> [userdata] ... Done
Writing [userdata_15.img] -> [userdata] ... Done
Writing [userdata_16.img] -> [userdata] ... Done
Writing [userdata_17.img] -> [userdata] ... Done
Writing [userdata_18.img] -> [userdata] ... Done
Writing [userdata_19.img] -> [userdata] ... Done
Writing [userdata_20.img] -> [userdata] ... Done
Writing [userdata_21.img] -> [userdata] ... Done
Writing [userdata_22.img] -> [userdata] ... Done
Writing [userdata_23.img] -> [userdata] ... Done
Writing [userdata_24.img] -> [userdata] ... Done
Writing [userdata_25.img] -> [userdata] ... Done
Writing [userdata_26.img] -> [userdata] ... Done
Writing [userdata_27.img] -> [userdata] ... Done
Writing [userdata_28.img] -> [userdata] ... Done
Writing [userdata_29.img] -> [userdata] ... Done
Writing [userdata_30.img] -> [userdata] ... Done
Writing [userdata_31.img] -> [userdata] ... Done
Writing [userdata_32.img] -> [userdata] ... Done
Writing [userdata_33.img] -> [userdata] ... Done
Writing [userdata_34.img] -> [userdata] ... Done
Writing [userdata_35.img] -> [userdata] ... Done
Writing [userdata_36.img] -> [userdata] ... Done
Writing [userdata_37.img] -> [userdata] ... Done
Writing [userdata_38.img] -> [userdata] ... Done
Writing [userdata_39.img] -> [userdata] ... Done
Writing [userdata_40.img] -> [userdata] ... Done
Writing [userdata_41.img] -> [userdata] ... Done
Writing [userdata_42.img] -> [userdata] ... Done
Writing [userdata_43.img] -> [userdata] ... Done
Writing [userdata_44.img] -> [userdata] ... Done
Writing [userdata_45.img] -> [userdata] ... Done
Writing [userdata_46.img] -> [userdata] ... Done
Writing [userdata_47.img] -> [userdata] ... Done
Writing [userdata_48.img] -> [userdata] ... Done
Writing [userdata_49.img] -> [userdata] ... Done
Writing [userdata_50.img] -> [userdata] ... Done
Writing [userdata_51.img] -> [userdata] ... Done
Writing [userdata_52.img] -> [userdata] ... Done
Writing [userdata_53.img] -> [userdata] ... Done
Writing [userdata_54.img] -> [userdata] ... Done
Writing [userdata_55.img] -> [userdata] ... Done
Writing [userdata_56.img] -> [userdata] ... Done
Writing [userdata_57.img] -> [userdata] ... Done
Writing [userdata_58.img] -> [userdata] ... Done
Writing [userdata_59.img] -> [userdata] ... Done
Writing [userdata_60.img] -> [userdata] ... Done
Writing [userdata_61.img] -> [userdata] ... Done
Writing [userdata_62.img] -> [userdata] ... Done
Writing [userdata_63.img] -> [userdata] ... Done
Writing [userdata_64.img] -> [userdata] ... Done
Writing [userdata_65.img] -> [userdata] ... Done
Writing [userdata_66.img] -> [userdata] ... Done
Writing [userdata_67.img] -> [userdata] ... Done
Writing [userdata_68.img] -> [userdata] ... Done
Writing [userdata_69.img] -> [userdata] ... Done
Writing [userdata_70.img] -> [userdata] ... Done
Writing [userdata_71.img] -> [userdata] ... Done
Writing [userdata_72.img] -> [userdata] ... Done
Writing [userdata_73.img] -> [userdata] ... Done
Writing [userdata_74.img] -> [userdata] ... Done
Writing [userdata_75.img] -> [userdata] ... Done
Writing [userdata_76.img] -> [userdata] ... Done
Writing [userdata_77.img] -> [userdata] ... Done
Writing [userdata_78.img] -> [userdata] ... Done
Writing [userdata_79.img] -> [userdata] ... Done
Writing [userdata_80.img] -> [userdata] ... Done
Writing [userdata_81.img] -> [userdata] ... Done
Writing [userdata_82.img] -> [userdata] ... Done
Writing [userdata_83.img] -> [userdata] ... Done
Writing [userdata_84.img] -> [userdata] ... Done
Writing [userdata_85.img] -> [userdata] ... Done
Writing [userdata_86.img] -> [userdata] ... Done
Writing [userdata_87.img] -> [userdata] ... Done
Writing [userdata_88.img] -> [userdata] ... Done
Writing [userdata_89.img] -> [userdata] ... Done
Writing [userdata_90.img] -> [userdata] ... Done
Writing [userdata_91.img] -> [userdata] ... Done
Writing [userdata_92.img] -> [userdata] ... Done
Writing [userdata_93.img] -> [userdata] ... Done
Writing [userdata_94.img] -> [userdata] ... Done
Writing [userdata_95.img] -> [userdata] ... Done
Writing [userdata_96.img] -> [userdata] ... Done
Writing [userdata_97.img] -> [userdata] ... Done
Writing [userdata_98.img] -> [userdata] ... Done
Writing [userdata_99.img] -> [userdata] ... Done
Writing [userdata_100.img] -> [userdata] ... Done
Writing [userdata_101.img] -> [userdata] ... Done
Writing [gpt_main0.bin] -> [PrimaryGPT] ... Done
Writing [gpt_backup0.bin] -> [BackupGPT] ... Done
Applying Patches... . . . . . . . . . . . . . Done
Resetting device... Done
Operation Finished.
The Following 3 Users Say Thank You to spd3 For This Useful Post:
Old 05-14-2017, 07:50   #36 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
Updated Program XML Handling
- Now it will simply skip flashing of missing files, instead of showing any error.
- Previously it was showing "file missing" message and flashing was not started.
- Please note, that some missing files from firmware may cause boot-loop.
fine method, but need step for soft must show which file have
issue or missing, after that decision are easy to flash or not
The Following 2 Users Say Thank You to shahabuddin For This Useful Post:
Old 05-14-2017, 09:14   #37 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
Originally Posted by deepanshu_ag View Post
how to remove mi account in mi note4 64gb
please have a look here
http://forum.gsmhosting.com/vbb/f979...ethod-2217536/
press thanks if it helped
The Following User Says Thank You to sagarjais For This Useful Post:
Old 05-14-2017, 09:50   #38 (permalink)
Member: 2635974
Thanks Meter: 45
Great Update.. Wooo thank uuuuu UMT BEST TEAM!
Old 05-14-2017, 11:19   #39 (permalink)
Member: 2424934
Thanks Meter: 22
Pleas umt team aad oppo f1s pattern unlock support
Old 05-14-2017, 11:43   #40 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Originally Posted by jatjag View Post
You only saying other tool failed & comparing your product with
other tools as they cannot even boot cpu in your first post.
so let me tell you other tools have fast boot options & you don't?
Is it fine now?
Comparing means mentioning other tools name.
Btw, they deserved that.
And about fastboot option, we will add it when we plan, till then, if you really need what we already have in our tool you can use it, if not, don't use it.
We NEVER promised what we are not going to do. Simple
Br,
Ultimate Multi Tool
Old 05-14-2017, 18:05   #41 (permalink)
Member: 2470369
Thanks Meter: 19
Msm 8976pro and msm 8976 are same...?
Because i want to repair imei of samsung c900f (c9 pro)
Is that plssible to do that with selecting msm8976..?
Pls reply umt team
Old 05-14-2017, 18:16   #42 (permalink)
Member: 2653615
Sonork: 100.1675715
Thanks Meter: 17
Very Good Update UMT Team
Please Add Huawei Frp Reset
Thank You...
Old 05-14-2017, 20:00   #43 (permalink)
Member: 1898834
Sonork: abdelhakim.ch
Thanks Meter: 14
can this update repair huawei CAN-L01
Old 05-15-2017, 10:54   #44 (permalink)
Mubashir999's Avatar
Member: 2570477
Thanks Meter: 427
good job UMt team . . .. .
Old 05-15-2017, 11:09   #45 (permalink)
U.M.T's Avatar
Member: 2465108
http://forum.gsmhosting.com/vbb/f970...-more-2224857/
Br,
Ultimate Multi Tool
Page generated in 0.28985 seconds with 8 queries
