02-15-2024, 14:27 | #17 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | Added Samsung Unbrick Function - It can unbrick devices even with completely erased flash and erase partition table - Just select PIT file from Unbrick_Fw folder created by TAR to Unbrick Converter - Tick ReCreate Partition Table only if partition table is destroyed or fully erased you check for supported devices listed |
02-15-2024, 16:59 | #19 (permalink) |
Freak Poster Join Date: Nov 2006 Location: SAHIWAL
Member: 396575 Status: Offline Thanks Meter: 65 | - Samsung KG Bypass - NEW!!! - Samsung Unbrick / Dead Boot Repair - NEW!!! - Samsung TAR to Unbrick Firmware Creator - NEW!!! GOOD UPDATE, WAS WAITING A LONG TIME SAME AS MEDIATEK PLZ |
02-16-2024, 03:17 | #23 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Added Samsung TAR to Unbrick Firmware Converter - No need to extract/rename file one by one - It will extract all required files in selected folder - You can use this extracted in QcFire Flash Tab > Samsung Unbrick group to repair dead boot devices - Always use same or higher BIT firmware for successfull unbrick operation How to usethis feature? is there video how to useit? |
02-16-2024, 04:34 | #24 (permalink) |
Major Poster Join Date: Dec 2013 Location: rio claro/sao paulo/brasil
Member: 2091511 Status: Offline Thanks Meter: 9 | Device : Samsung Galaxy S22 5G (SM-S901E) U7 Operation : Samsung KG Bypass Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. SAMSUNG : Turn Off phone, hold EDL Cable Button and insert to phone and press VOL DOWN + POWER on phone more than 3 times rapidly and then leave EDL Cable Button. Found Port : Qualcomm HS-USB QDLoader 9008 (COM17) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...Done Protocol v3 or higher detected. Auto Loader unsupported. Initializing Protocol...OK Using Pre-Defined Loader [SMS901E_U7.ufl] Preparing Loader...Done Sending Loader [SMS901E_U7]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : , UFS, 256 GB LU Count : 6 [0x03B6B400] [0x00000800] [0x00000800] [0x00000400] [0x00028000] [0x00001000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK [Sign] Build : S901EXXS7DWLA Int. Build : SM-S901E_SEA_DX_QKEY2 Bypassig KG Lock... Done Done Done Done Once phone reboot in Odin Mode, full flash your device. Operation Finished. |
The Following User Says Thank You to aldineipresb For This Useful Post: |
02-16-2024, 13:33 | #28 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Added Samsung TAR to Unbrick Firmware Converter - No need to extract/rename file one by one - It will extract all required files in selected folder this is not understood how to make |
