02-16-2024, 18:31 | #31 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,457 | Quote:
Br, UMT | |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
02-18-2024, 18:19 | #33 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | A525FXXS6DWK2 frp QcFire Ver. 9.3 Code: Device : Samsung Galaxy A52 (SM-A525F) BIT6 Operation : Samsung Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. SAMSUNG : Turn Off phone, hold EDL Cable Button and insert to phone and press VOL DOWN + POWER on phone more than 3 times rapidly and then leave EDL Cable Button. Found Port : Qualcomm HS-USB QDLoader 9008 (COM28) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...Failed Operation Finished. QcFire Ver. 9.3 Code: Device : Samsung Galaxy A52 (SM-A525F) BIT6 Operation : Samsung Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM28) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. SAMSUNG : Turn Off phone, hold EDL Cable Button and insert to phone and press VOL DOWN + POWER on phone more than 3 times rapidly and then leave EDL Cable Button. Found Port : Qualcomm HS-USB QDLoader 9008 (COM28) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...Failed Handshake Sequence Error Ignored! Initializing Protocol...OK Using Pre-Defined Loader [SM-A525F BIT6.ufl] Preparing Loader...Done Sending Loader [SM-A525F BIT6]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 9.2 |
02-18-2024, 19:58 | #35 (permalink) | |
Close any other application running which may interfere with port. Br, UMT | |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
02-29-2024, 11:26 | #40 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | Quote:
ok | |
The Following User Says Thank You to i_seeque For This Useful Post: |
03-02-2024, 17:41 | #41 (permalink) |
Freak Poster Join Date: Apr 2004 Location: MOROCCO
Member: 62545 Status: Offline Thanks Meter: 43 | Device : Samsung Galaxy A52 (SM-A525F) BIT6 Operation : Samsung Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. SAMSUNG : Turn Off phone, hold EDL Cable Button and insert to phone and press VOL DOWN + POWER on phone more than 3 times rapidly and then leave EDL Cable Button. Found Port : Qualcomm HS-USB QDLoader 9008 (COM105) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00002000 OPK_DATA : 36E60270BD33E72EA2DE1D42607BFE83C90B16C4236EC83747 F7AE14535FB63E Initializing Protocol...OK Using Pre-Defined Loader [SM-A525F BIT6.ufl] Preparing Loader...Done Sending Loader [SM-A525F BIT6]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SM6250, UFS, 128 GB LU Count : 6 [0x01DA3400] [0x00000800] [0x00000800] [0x00000400] [0x00025800] [0x00000800] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Software : TP1A.220624.014.A525FXXS6DWK2, A525FXXS6DWK2 [Wed Nov 29 15:59:32 KST 2023] Android Ver. : 13 Patch Level : 2023-12-01 Reset FRP... Done Operation Finished. QcFire Ver. 9.3 |
The Following 3 Users Say Thank You to y_info2004 For This Useful Post: |
03-09-2024, 13:51 | #42 (permalink) |
Junior Member Join Date: Dec 2023
Member: 3053379 Status: Offline Thanks Meter: 14 | Model : Oppo F17 (CPH2095) Operation : Erase Userdata Found Port : Qualcomm HS-USB QDLoader 9008 (COM25) Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1D01400 [SDM662] 00005100 OPK_DATA : 19CF99D55CA3B2E11EA19E52E3541DEDF01898FD9F8C40E625 48F1C7F60ABD47 Initializing Protocol...OK Preparing Loader...Done Sending Loader [CPH2095]...Done Executing Loader...OK Initializing Storage...OK Read : Allowed Write : Protected Alt. Write : Allowed Alt. Write is allowed, using Factory Format Method...Done Erasing FRP Data...Done Operation Finished. QcFire Ver. 9.3 |
The Following 2 Users Say Thank You to Fast Fix For This Useful Post: |
03-11-2024, 07:47 | #43 (permalink) |
Member: 3053379 Status: Offline Thanks Meter: 14 | Device : Vivo V11 Pro Operation : Vivo Format FS / FRP Reset Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_029]...Done Executing Loader...OK SMEM Check Pass! Detecting Storage Type...OK Hardware : 8937, EMMC, 32 GB Reading Partition Table...OK Reading Device Information...OK Android Ver. : 11 Patch Level : 2022-03-01 Formatting userdata...DonePatched OK Resetting FRP Lock...Done Wipe cache / userdata from Recovery and reboot. First startup may take 2-5 minutes. Operation Finished. QcFire Ver. 9.3 |
03-12-2024, 16:41 | #44 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: UA
Member: 810029 Status: Offline Thanks Meter: 8 | Quote:
HI, I canot find a decision how to reset FRP on Samsung Galaxy s22 sm-s901b? Can you help me,please ? | |
03-17-2024, 15:12 | #45 (permalink) |
Insane Poster Join Date: Jul 2014 Location: Nigeria
Member: 2230199 Status: Offline Thanks Meter: 13 | Umt is the best team always working very hard to impress it's users thanks for lg q92 it's actually world first |
The Following User Says Thank You to dondav7 For This Useful Post: |
