03-15-2024, 09:01 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | [15-03-24] UMTv2/UMTPro UltimateMTK v1.2 - Vivo Demo, Samsung Unbrick and more... Innovative and Intelligent UltimateMTK2 v1.2 The Ultimate MediaTek Tool What's New: Added Vivo Demo Reset (New) - Tested on Vivo T2x 5G and Y28 5G Added Vivo Demo Reset (Old) - For devices not supported by New Method Added Samsung Unbrick and TAR Flashing - Simple and Easy way to Unbrick Samsung Devices - NO NEED OF UNBRICK FIRMWARE ANYMORE - Supports Completely Formatted Flash Chips - Creation GPT on the fly if it is Erased - No need to use Odin to flash after Unbrick if used BL/AP/CP/CSC - Flashing any Single TAR is supported if GPT is intact - Incase of fully formatted flash chip, you must use BL/AP/CP/CSC - Use of same or higher BIT Firmware is recommended to fully recover device - Software will automatically use preloader from BL if device is connected in BROM mode Added Read Dump - Simple and Easy Tool to make Full Dump - Backup BOOT1/BOOT2 and USERAREA - USERAREA dump is completely customizable - You can choose either FULL or set own Start/Length for USERAREA - Auto detect if save location has enough free space to save dump Added Write Dump - You can write back dump created by Read Dump function - Just select CFG file and tick parts of dump you want to write - Writing DUMP from one device to another is not recommended - Make sure to backup security partitions before writing DUMP from another device Fixed "Lost in background" issue on Confirmation Dialog at Startup Improved Format Functions Improved Write Flash Function Minor UI Changes Important Notes: - You can flash device with both BROM and Preloader mode - If default DA does not work, use own DA in custom DA - Force BROM may not work on new security, use Test Point instead - When using Test Point, you must select Preloader in PL (not needed when flashing) - If you need to connect device in Preloader mode, you must select PRELOADER in connection settings, otherwise software will try to Crash Preloader (may not work on new security devices) Note : Some features are device/OS specific and may not work on all devices. WARNING: ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI. ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS. WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE. Download using Support Access or Mirrors Official Website: Ultimate Multi Tool UMT Pro Br, UMT |
The Following 36 Users Say Thank You to Fast Unlocking For This Useful Post: |
03-15-2024, 09:58 | #3 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Online Thanks Meter: 1,115 | always happy update from umt team Last edited by Fast Unlocking; 03-15-2024 at 17:21. |
The Following User Says Thank You to djj007 For This Useful Post: |
03-15-2024, 20:07 | #9 (permalink) | |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | Samsung A12 Dump Read Done via UMT Quote:
P.S: Read Time Full Dump : 1 Hour 45 Minutes 1h .45m | |
The Following 3 Users Say Thank You to boganice For This Useful Post: |
03-15-2024, 20:18 | #10 (permalink) | |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | Quote:
The Following 2 Users Say Thank You to Fast Unlocking For This Useful Post: |
03-15-2024, 22:58 | #13 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,445 | Quote:
Br, UMT | |
The Following User Says Thank You to U.M.T For This Useful Post: |
03-15-2024, 22:58 | #14 (permalink) | |
Br, UMT | |
03-15-2024, 23:03 | #15 (permalink) | |
Member: 5184 Status: Offline Thanks Meter: 246 | Quote:
I will Try again now using HI Speed Option and let you know.. thx UMT Team we have to thankfull coders and programmer tool because they doing the best for us Regarding save size user data ,, which start hex and length hex I can use ? it appears : [00000001BDC00000] [0000000CD1800000] Last edited by boganice; 03-15-2024 at 23:12. | |
