05-15-2017, 14:49 | #16 (permalink) |
Freak Poster Join Date: Jun 2015 Location: KORBA CHHATISHGARH INDIA
Member: 2418156 Status: Offline Sonork: 1677163 Thanks Meter: 16 | |
05-15-2017, 15:30 | #18 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
For further details, please use search. Br, Ultimate Multi Tool | |
05-15-2017, 18:20 | #20 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | If it is Qualcomm and can enter download mode, then yes. Br, Ultimate Multi Tool |
The Following User Says Thank You to U.M.T For This Useful Post: |
05-16-2017, 04:49 | #22 (permalink) |
Insane Poster Join Date: Oct 2015 Location: bangalore
Member: 2470369 Status: Offline Thanks Meter: 19 | Msm 8976pro and msm 8976 are same...? Because i want to repair imei of samsung c900f (c9 pro) Is that plssible to do that with selecting msm8976..? Pls reply umt team Pls.. |
05-16-2017, 04:56 | #23 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | If you can put Samsung in EDL, then yes, you may try. I really not found any samsung device entering EDL. About IMEI repair, Generic Qualcomm and samsung are really very different. Br, Ultimate Multi Tool |
05-16-2017, 08:00 | #25 (permalink) | |
Member: 2470369 Status: Offline Thanks Meter: 19 | Quote:
Sir is that possible to repair imei of samsung c900f with umt...? Can u add the feature of samsung qualcomm support? | |
05-16-2017, 14:55 | #28 (permalink) | |
No Life Poster Join Date: May 2007 Location: Gujarat,India
Member: 517102 Status: Offline Sonork: 100.1601229 Thanks Meter: 199 | Quote:
Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM58) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1600500 [8917] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8937_4..ufl]... Write Error! Please use correct loader and check USB port / cable. Module Ver. 0.9 | |
05-16-2017, 15:02 | #29 (permalink) |
Member: 517102 Status: Offline Sonork: 100.1601229 Thanks Meter: 199 | with 8917 loader... Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM58) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1600500 [8917] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8917.ufl]... Write Error! Please use correct loader and check USB port / cable. Module Ver. 0.9 |
