-   Ultimate Multi Tool Box (http://forum.gsmhosting.com/vbb/f970/)
-   -   [15-05-17] Ultimate Multi Tool QcFire v0.9 - Fixed Mi5 Flashing and more... (http://forum.gsmhosting.com/vbb/f970/15-05-17-ultimate-multi-tool-qcfire-v0-9-fixed-mi5-flashing-more-2224857/)
U.M.T 05-15-2017 11:51
We are pleased to announce
Ultimate Multi Tool - QcFire v0.9
The Ultimate Qualcomm Module
Repair almost all Qualcomm Devices supporting Firehose Protocol
Supported Brands
- Alcatel
- Cherry Mobile
- Coolpad
- HTC
- Huawei
- Lenovo
- Lyf
- Micromax
- OnePlus
- Oppo
- Swipe
- Vivo
- Xiami
- YU
Supported CPUs for Auto Detection
- 8610
- 8909
- 8916
- 8917
- 8929
- 8936
- 8937
- 8940
- 8952
- 8953
- 8974
- 8976
- 8992
- 8994
- 8996
- 8996
- 8x10
- 8x26
Supported CPUs with Internal Loaders:
- 8610
- 8909
- 8916
- 8917
- 8929
- 8936
- 8937
- 8940
- 8952
- 8953
- 8974
- 8976
- 8992
- 8994
- 8996
- 8996
- 8x10
- 8x26
Enhanced Xiaomi Mi5 (MSM8996) Flashing
- To flash all rawprogram files, you need to select them one by one.
- We will automate it for such firmwares in coming updates.
Added Autodetection of Redmi 1s
Added Loader for Vivo Y55
- Incase of Vivo Y55, please untick Auto and select 8937_4 manually.
Fixed Booting Issue on some MSM8996 Devices
- Some users were getting issue on getting Payload Information.
Fixed FRP Reset for Some Devices, was Broken in 0.8
- We again recommend to make Security Backup first.
Updated Automatic Patch File Select Method
- Now for rawprogram_unsparse etc, it will auto select required Patch file.
Added Warning in Log incase some parts of Firmware are missing.
- You can now decide before flashing if you want to flash with these files missing.
Other Improvements which we forgot to mention :p
COMMON ERRORS AND FIXES
- Write Err while sending loader.
- It means that selected loader (either manual or auto) is not compatible with hardware. You should try with other loader for same CPU (as mostly all CPU will be detected perfect with QcFire), or use Factory Loader which often comes with Firmware.
- Init Handshake Sequence Failed.
- Common communication problem with phone. Try to connect phone again in download mode and try operation again.
Reading Pattern Data... Data Missing! Failed
- Read Pattern is supported only on Android older than 6.x. It should work fine with 5.x and lower Android Versions.
- Mi Account Not Active
- It means that Mi Account data was not found. Check if phone asks for Mi Account on startup. Otherwise, Format FS, turn phone ON, then turn OFF and try again.
- Warning! High Speed Driver not installed.
- This will seriously downgrade Reading performance. Please update driver from QcFire\Drivers folder. However, it should not affect flashing procedure.
*** SPECIAL THANKS TO OUR VALUABLE USERS FOR THEIR CONTINUOUS SUPPORT ***
It Has Begun...
Stay Tuned...
More Amazing Updates On The Way...
ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS.
WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE.
:: NO FAKE ADVERTISEMENT ::
:: NO FAKE UPDATES ::
:: NO FAKE WORLD'S FIRST ::
:: NO FAKE BLA BLA BLA ::
PARTICIPATE IN FREE UMT CONTEST AND WIN
Why Waiting? Buy Today and Feel the Difference
Choose Your Reseller Now and Feel The Real Ultimate Tool
How to Download:
- Download UMT Support Access.
- Connect UMT Box/Dongle to PC and Run UMT Support Access.
- Download required Executable from Installer folder.
- Enjoy!
- Download Mirror - Google Drive.
Br,
Ultimate Multi Tool
Gsm.Universal 05-15-2017 11:56
researved for taem news
AAJETH 05-15-2017 12:27
3s prime mi ac disable done
http://i893.photobucket.com/albums/a.../Capture_2.jpg
naseer raza 05-15-2017 12:46
dear team please add imei repair option in qualcume cpu in next update
nahidroman 05-15-2017 12:53
Nexrt update qualcomm imei repair
jatjag 05-15-2017 12:58
Still no fastboot options while others support.
You deleted my six messages requesting same.
Is this your support?
FactoryFilePak 05-15-2017 12:58
Lenovo A6020a46 [msm8916] FRP Reset Done By Ultimate Multi Tool Box
Operation        : Reset FRP
Checking for existing devices... Found
Port        : COM26
Opening Port... OK
Init Handshake Sequence... OK
Hardware ID        : E1B09000 [8936] 01000100
Initializing Protocol... OK
Using Auto Selection
Preparing Firehose Loader... Done
Sending Loader [8936_1.ufl]... Done
Executing Loader... OK
Hardware        : 8936, eMMC, 16 GB
Payload Info        : In: 262144 [4096], Out: 16384, Sector Size: 512
Reading Partition Table... OK
Reading Device Information... OK
Device        : LENOVO Lenovo A6020a46 [msm8916]
Software        : A6020a46_S048_160701_ROW, A6020a46_S048_160701_ROW [2016年 07月 01日 星期五 20:52:08 CST]
Android Ver.        : 5.1.1
Resetting FRP Lock... . . . . . Done
Operation Finished.
Module Ver. 0.9
http://i.imgur.com/hNltyh4.gif
http://i67.tinypic.com/2urnyxf.gif
FactoryFilePak
Mobile_Care 05-15-2017 13:10
Still UMT CDMA Give Dongle Update Error
Solved Plz
U.M.T 05-15-2017 13:23
As per support, your every stupid post should be deleted.
Stop behaving like an idiot or we will make sure to ban you from here.
No regards,
U.M.T 05-15-2017 13:24
Solved Plz
It is not CDMA update.
We will release it soon.
Br,
Ultimate Multi Tool
U.M.T 05-15-2017 13:25
It is already in GSM Module.
Br,
Ultimate Multi Tool
ashish800 05-15-2017 13:32
pls fix card deffrent update problume 3.8 and 0.9
jatjag 05-15-2017 14:10
requesting fastboot support is stupid post?
Don't you have manners to answer senior member?
You are the only behaving like idiot .
Prove any of my post requesting for fast boot as stupid.
jamaletw 05-15-2017 14:18
no any problam my card update ok qcfiire.0.9 umt.3.8
U.M.T 05-15-2017 15:28
You arr simply an idiot. With no manners. No knowledge. Just plain idiot. Just search your own posts in other forums too.
All your posts will be deleted in next few mins. After that we will also see if we should block you or not.
No regards
Page generated in 0.31238 seconds with 5 queries
